Question about Linksys WRT300N Wireless Router
I want to know the default ip address for my lynksys router
    Genius:
  • 1,044 Answers
192.168.1.1
Posted on Aug 25, 2010
What Is the Default IP Address of Belkin Router? And determine Admin password?
HI ! HERE YOU GO!
https://www.lifewire.com/what-is-the-default-ip-address-of-a-belkin-router-818062
How to Find the Default IP Address of Belkin Router
Oct 24, 2017 | Belkin Computers & Internet
I have the Lynksys wireless-G 2.4GHz , I want to change my Password can you tell me how to do it pls. Thank you
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
Sep 15, 2011 | Computers & Internet
Hi, i have a problem in lynksis WRH54G. I have changed my network service provider a few days ago, starting that day i couldn't use my lynksis wireless router anymore. it looks like it's working properly...
You need to reconfigure your WAN settings of router to your new internet service provider settings.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router.
Click on WAN settings in general setup and set as your service provider settings.If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jan 05, 2011 | Linksys WRH54G Wireless Router
Forgot password for reinstalling router model #wrt54G
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then enable WEP security and enter WEP key it is your password to connect wifi.Then save settings and restart router . Then when anybody try to connect your wifi it ask for that password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 28, 2010 | Linksys Wireless-G WRT54G Router
Have lynksys wireless router but is unsecure -
You can enable WEP on your router to make your wireless network secure.
To access the screen of the router, type the ip address of the router in the address bar of Internet explorer or Firefox. By default the ip address of the router is 192.168.1.1. If this doesn't work, go to the command prompt (Start -> run -> type cmd). Type ipconfig. Copy the default gateway.
It will prompt you for a user name and password. By default leave the user name blank and then type admin in the password field.
Once you are in the Linksys screen, go to the Wireless tab -> Wireless security.
For the security mode, select WEP.
WEP encryption: 64bits 10 hex digits.
On the Passphrase field, type a wireless password of your choice, then click Generate.
It will give you a key. You will need to copy the wireless network key because you will need to enter this key on your PS3 and laptop. Take note that this is also case sensitive.
Once you click save settings, it will disconnect all your wireless computers.
You will need to manually enter the wireless network key on all your wireless devices. Without the network key, other computers will not be able to connect to your network.
I hope this helps.
Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated.
Feb 16, 2010 | Linksys Wireless-G Broadband Router
Installed a new lynksys router and now can't 'find' it. I contacted lynksys support and they could not find a solution. Old lynksys router had a differenct IP address
IP addresses in a a home system are normally assigned dynamically (that means they are not necesarily always the same). If you require it (or any other device on your network) to have a particular address, you must set it to that address.
Network Magic from Cisco can help you to do this.
I hope this helps you
a
Sep 28, 2009 | Linksys NSLU2 Network Storage Link
Cant obtain ip adress
Have you set up your lynksys to allow wireless QoS? If not go to your lynksys broadband wireless software. If you don't know how enter 192.168.1.1 into your explorer bar, log in with lynksys, default is top line blank password 'admin', go to Applications and Gaming tab and enable Wireless QoS, you'll also see all of the places to establish and open ports for specific applications.
May 09, 2009 | Linksys WRT160N Wireless Router
Disable internet access
Access your router Setup page
Open internet explorer go to http://192.168.1.1 (default) username: admin (default) password: "leave it blank" (default)
Go to Security go to Filter
if you know that Ipaddress of the computer you want to block for example 192.168.1.10
You can create up to five different IP Address Range filters   Users who have  filtered  IP addresses will not be able  to  access the  Internet at all   If you only want to filter one  IP  address instead of a range of IP addresses, enter the same  value into both fields  For instance, if you wish to filter the  PC with  the  IP  address of 192 168 1 5, enter 5  into both  fields on one line: 192 168 1 5 ~ 192 168 1 5
if you know the MAC address of the computer click the Edit MAC Filter Setting and input the MAC address you want to block.
blocking by MAC address is the most effective solution to block a computer... while blocking by ip address will be easily bypass by changing the ip add of the pc
then saved your settings and reboot..
Jan 30, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys WRT300N Wireless Router Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
