Question about Ryobi Drills
How do I change chuck? - Ryobi Drills
  • 2,176 Answers
Go to the tip section and there are detailed instructions on how to do this, also you can go to my profile area under tips/hints and they are there also
Posted on Aug 26, 2010
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
Top chuck just clicks but won't change bit size?
It sounds as though you will have to replace the chuck. Remove the screw (l/h tread) from inside the chuck first before removing it.
Feb 02, 2013 | Drills
Need anew chuck for a black & decker BD155RT Quattro 550w drill and advice on how to change it
Remove the left hand screw from inside the chuck and then insert the chuck key onto the chuck, place the machine on a suitable work surface and give it a wack so that the chuck will unscrew off the drill anti clockwise.
Jan 22, 2013 | Drills
How to change the chuck on a ryobi EID1000RE
hello, there is a screw you have to remove inside of the chuck once you have done this you should be able to unscrew the chuck,,
Feb 07, 2012 | Garden
3/8" cordless driver can't change the
If debris enters the chuck it may no longer turn for adjustment. Spray plenty of wd40 into chuck and allow plenty of time for oil to do its magic. Hold chuck/drill pointing down and turn drill in both directions to clean out debris. If chuck is too far gone, remove the center screw (backwards thread) and remove the chuck(threaded on). Replace the chuck with new generic part from Lowes (about $25.).
Sep 20, 2011 | Dewalt Drills
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
Chuck will not hold bits, How to change chuck
down inside the chuck theres a big flat head screw that should do it.
Nov 17, 2010 | Hitachi DS18DVF3 18 volt Cordless Drill...
Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How to change a nozzel
to change the chuck you must remove the screw inside chuck by turning clockwise as it is cross threaded then place an allen key in chuck tighten and hit several times with hammer till chuck lossens
Feb 23, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
