Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi blue convergence problem. Parts?
I have a hitachi 51uwx20b and the blue convergence is bad.... I need to know if I need to replace the entire circuit board or just some parts? Also part numbers would be very helpful. And any other help or advice would be Great!
  • 1 more comment
  • Suctoes May 31, 2008
    I went in and replaced the IC chip sets.... Now it works great.
  • GinoD Jun 16, 2008
    I have a hitachi 53 inch that does not do auto convergence. When the button is pushed i get a message on the screen that says STATIC MODE. Can someone help me out on this?
  • ttommyturbo Jun 25, 2008
    55" hitachi bule color bowed out will not line up tryrd to ajust but now i have 3 color shadows how can i get this ajusted from the circuit board tv repair person wants too much to fix this anolog projection tv please advise
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
  • Swilin Sampson
    Swilin Sampson Jun 14, 2008
    Kindly close this thread with a Fixya rating if the issue is resolved. Thank you.
Set 51uwx20b, how do i fix magic flash to reset factory settings
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
Nov 22, 2011 | Hitachi 51UWX20B 51" Rear Projection...
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
Red shade to ever one
Convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites like Tv repair, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Apr 20, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Double image
Problem seems in convergence out section.
TV needs Convergence Out ICs replacement.
If you have TV repair experience and know good soldering work then you can give it try OR get help of qualified TV tech to fix it.
If you need further help, let me know.
Dec 30, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Hitachi 51UWX20B Projection TV
Hitachi part number JT23051 is Obsolete the new part number for the Deflection Convergence PWB is JT23051R its available from Hitachi for around 350.00
Oct 08, 2008 | Televison & Video
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Blue convergance on Hitachi 43FDX10B
Replace both STK IC's.....use kit # X480293....any other parts
will fail prematurely..................After replacing convergence IC's
activate Magic Focus & you are usually done.................T.
Apr 03, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
662 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
