Question about Whirlpool 17.6 cu. ft. Top-Freezer Refrigerator w/ Factory-Installed Icemaker
I have tried to push item in top freezer and freezer went up at front a bit and not working but have checked plugs and all good however fridge freezer now not working. what can i do?
Take out what you put in!
Posted on Aug 25, 2010
Water is appearing under the front left foot (as you look at it). It builds up in to puddle over night. I have checked the instructions which are difficult to follow (not very clear English) but it said...
Freezer drain is plugged.
Two solutions:
1. Call a service repair company.
2. Turn off both controls (turn to lowest setting) and open freezer door for minimum of 24 hours (max 48 hours). That will thaw drain sufficiently.
What has happened: Somehow the freezer drain had ice build-up and eventually froze solid. Every time the unit went into defrost mode, the melted frost (now water) had no place to go. The normal exit is the freezer drain hole which leads to the drip pan underneath. That exit is plugged with ice, so the water went where it could - across the freezer floor and out the bottom of the freezer door. You found it and wondered why.
Mar 20, 2011 | AEG S75348KG Bottom Freezer Refrigerator
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
Kenmore top freezer fridge beeping problem
Sounds like your on the right track. The switch getting warm is a bit of an issue, but that could be normal operation depending on a number of factors.
But, your right, the switch pops out from the front. Be sure and disconnect power before you attempt this as you don't know if the switch is on 120VAC or a low voltage power from the controller.
Dec 16, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a ten year old Whirlpool top freezer refrigerator that was recently repaired for non cooling. I believe my landlord replaced the thermostat but somehow was unable to properly reinstall the drainage...
Good day,
There is a drain cup in the rear top center of the fridge compartment that drains the water to the outside of the machine, down a drain pipe into the drain pan.
Hard to see the cup unless you use a hand mirror.
Dirt, can plug this cup and as well the hose and fittings in the back of the machine.
Removing this cup requires removing the front cover, and between cleaning it, the connection between the inside and outside of the machine and the drain hose can be tedious.
Don't force the situation. Shut the machine down, until it is completely defrosted.
Nov 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
My Amana refrigerator freezer is totally off.
Ouch!
You may have lost your fridge. Try This.
  1. Unplug.
  2. Take a table lamp & plug into socket where you had fridge plugged in. Turn light on. If it lights. Fridge is trouble.
  3. If no light check another socket make sure light works if it works your socket, wiring or breaker is your problem.
  1. If fridge check wire to & from fridge make sure it is unplugged feel & look for crimp or gap in wire.
  2. Check connection to fridge some have a reset button or overload fuse. Reset or replace if you find one.
  1. If socket try another socket see if fridge runs.
  2. If it runs you will have to troubleshoot house wiring.
Contact me if you need more help. Good Luck!
Please rate if this fixed or was helpful. Thank you.
Mar 09, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Roper Refrigerator, top freezer leaking water into refrigerator
Hi I reckon you gave either an ice block in the defrost drain system or a blockage caused by loose food bits. You can clear the ice block if you keep the fridge off for 24 hours leaving both doors open. If you have a small table fan to circulate warm room air you could speed up the process.
The second type of block with food bits may need you to open the internal rear panel of the fridge and push through a stiff wire to clear the blockage.
Jul 15, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Fridge has hot spot
Hit it with a big stick!
Mar 24, 2008 | Refrigerators
Whirlpool 17.6 cu. ft. Top-Freezer Refrigerator w/ Factory-Installed Icemaker Logo
20 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
