A path 3.5 m wide runs inside along the boundary of a square field whose side is 65m .find the area of the path . also find the cost of manuring the rest of the field at the rate of rs.9 per sq.metre
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
The area of the path is 861 square metres.
It will cost Rs 4161.6 to manure the interior at Rs .9 per square metre.
Posted on Oct 23, 2014
Find the perimeter of a square whose area is 1225 cm2
I could just give you the answer of 140 cm
but I think you need to know how I got this answer
A square is an object that has equal sides
area is calculated by length multiplied by width
so 1225 cm^2 area by using the square root of 1225 cm^2 gives you 35 cm
so each side is 35 cm and there are 4 sides so 35 cm +35 cm + 35 cm + 35 cm = 140 cm
If you are doing homework always show how you got the answer because in an exam having the working out shown can sometimes result in getting some marks even if you slipped up slightly and got the wrong answer.
Nov 05, 2017 | The Computers & Internet
Are there 3 ft. in a sq yard?
No, there are 9 feet in a square yard.
Apr 23, 2015 | Building Materials
Why does Xerox 7335 truncates output from Oracle PDF?
It may not be the printer and I did some research on Oracle and this seems to be a common issue.
I pulled this information off an Oracle knowledgebase it may not resolve your issue and there is more info on the following site if you want to investigate further:
http://docs.oracle.com/cd/E23943_01/bi.1111/b32121/pbr_uxprt009.htm#RSPUB75727
NOTE:
If you're printing to the Xerox MFD with a PS (postscript printer driver) you could try installing and printing using the Xerox PCL driver for your computers operating system. If you printing reports from a mainframe this may be an issue at the mainframe level in which case I would engage your companies IT department for assistance.
Any one of a number of possible causes may account for the truncation of fields.
  • Check the field and determine if it is allowed to expand.
    1. In Oracle Reports Builder, double-click the field in the Paper Design or Paper Layout view to display the Property Inspector.
    2. Find the Horizontal Elasticity property.
    3. If it is set to Fixed, you should change it to Variable or Expand.
    4. Run the report to the printer.
    5. If it still truncates, it could be that the field requires multiple lines.
    6. Return to the Property Inspector for the field and check its Vertical Elasticity.
    7. If it is set to Fixed, you should change it to Variable or Expand.
    8. Run the report to the printer again.
  • If the right most fields on the page are always the ones truncating, it could be an issue with the printable area of the printer. If you are using a PCL printer, then you will have to estimate the size of the printable area and resize your margins accordingly:
    1. Open the report in Oracle Reports Builder.
    2. Go to the Paper Layout view.
    3. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins.
    4. Click and drag the black line to the left approximately 0.5 inches.
    5. Save and run the report to the printer again.
    6. If necessary, repeat steps 4 and 5 to determine approximately where the printable area boundary is located and then ensure that your report body fits within that area.
  • If you are using a PostScript printer, you can get the printable area boundary to appear in the Paper Layout view as follows:
    2. Choose File > Page Setup.
    3. Verify that the margins are small and that the orientation is correct.
    4. Click OK. The Paper Layout view should now be able to read the boundary.
    5. Go to the Paper Layout view.
    6. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins. A black hashed line also appears indicating the boundary of the printable area.
    7. Ensure that the thick black line is inside of the black hashed line. If it is not, click and drag the black line inside the printable area.
    8. Click the Margin tool to leave margin mode.
    9. If necessary, reposition your fields to fit within the new body boundaries.
    10. Save and run the report to the printer.
  • For PCL, if it is still truncating, try using a fixed space font instead of a proportional font. Sometimes PCL printers have problems interpreting proportional space fonts and it leads to truncation. You should try using a fixed space font, such as Courier, and possibly font aliasing.
    Note:
    Default layouts are built against a generic printer. Each printer has its own printable area. As a result, you may have to reset the report to fit the printer. Ideally, if you know the various printers you will be using, you can design the report from the start to fit the printer with the smallest printable area.
Mar 10, 2015 | Xerox Office Equipment & Supplies
Radiuse of a cricket pitch
The playing area shall be a minimum of 150 yards (137.16 metres) from boundary to boundary square of the pitch, with the shorter of the two square boundaries being a minimum 65 yards (59.43 metres)
Jul 12, 2014 | Cricket
What is the pyramid total surface formula
A pyramid has 5 sides including the base. If the base is a rectangle L long and W wide, its area is L*W.
The other sides are triangles. If the height of the pyramid is H, the triangles that are L wide at the base will have a height of the square root of half of W squared plus H squared, or SQRT((.5*W)^2+H^2) and the two that are W wide at the base will have a height of SQRT((.5*L)^2+H^2). The area of a triangle is .5*height*base, so the total surface two triangles with the same height and base is 2*.5*height*base = height*base.
So, the total surface area of a pyramid L long by W wide by H tall would be:
L*W (the area of the base)
+ L*SQRT((.5*W)^2+H^2) (the area of the 2 triangles with base L)
+ W*SQRT((.5*L)^2+H^2) (the area of the 2 triangles with base W)
Hope this is helpful!
May 23, 2014 | Encore Math Advantage Algebra II and...
One cube has a face equivalent to the total area of another cube. find the ratio of their volumes?
Let the sides of the cubes be a and b,
the length of the diagonal of the cube whose side is b is given as square root(3)*b
according to the given question,
a=square root(3)*b
the volume of the cube with side a is given as
v1=a^3=(square root(3)*b)^3
and the volume of the cube with side b is
v2=b^3
then their ratio of volumes is given as
v1/v2=3*square root(3)*b^3/b^3=3*square root(3)
i.e v1:v2=3*square root(3):1
Next qwasthun pwease :D
Jan 06, 2011 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Calculate the area of the room.room is 12feet long 10 feet wide 8feet tall
120 square feet of space is the floor space, along with the ceiling
wall 1 and 2 would be 80 square feet
wall 3 and 4 would be 96 square feet
over all inner room would be 960 square feet
12*8*10=960
Oct 17, 2010 | Televison & Video
Find the area of a square whose sides are (4x+3)meters long each.
To get area, multiply the two sides together.
(4x+3)(4x+3)
16x^2(i.e.squared) + 24x + 9
Proof : If x=2
then side would be 11m
area would be 121m squared
Using our formula,
64 + 48 + 9
or 121m squared
Mar 09, 2010 | Kodak Cameras
Find the surface area of awooden box whose shape
If this box is a cube, and each side is 15cm long, then each side has an area of 225 square centimeters. Since a cube has 6 sides, your cube's total surface area is 1350 square centimeters. This was a fun change from the normal question... but I don't get what you're trying to do. Thanks for the question.
Mar 04, 2010 | Adaptec Computers & Internet
Geometry-
this is a math problem?
the area of the old square was 100, the new one is 225
say the old squares side was X, so the area was X^2
the new square has area 2.25 X^2
take the square root to find the side of the new square: 1.5 X
so we know that the side of the old square plus 5cm is the side of the new square. so X + 5 = 1.5 X
solve that to find X = 10,
so the area of the old square was X ^ 2 = 100
and the area of the new square is 2.25 X ^ 2 = 225 :)
Aug 10, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
