Question about Konica Minolta Office Equipment & Supplies
I have a Minolta QMS Print System 2650. When I turn it on, Im getting 'Fatal Error: HSYNC Detect Abnormal'. Im not sure what to do.
Hi Mine did this too and minolta said it was the fuser assembly but they wanted a few hundred for the repair, was cheaper to get a new laser, did you solve your issue yet?
Posted on Dec 27, 2010
Printer get a H-sync error on read out and stops printing.
Replace the print head which house the LASER and polygon motor. mite check connection to main board and print head.
Feb 10, 2011 | Minolta QMS PagePro 9100 Laser Printer
Konica minolta pagepro 9100 laser print Error message upper output bin full
check the sensor. for the upper output pin. it mite need to be replaced.
Dec 16, 2010 | Minolta QMS PagePro 9100 Laser Printer
Konica minolta pagepro 1350w fatal print spooler error?does that mean i need a new toner cartridge or is the damn thing busted?
A 'print spooler' is a range of memory either internal to the printer (sometimes called 'buffer memory') or set aside from the RAM in your system. A fatal error normally means the material you tried to print has been lost and must be sent to the printer again. If the error continues to show up, you may have bad printer memory or perhaps the driver software in your system has gotten stepped on by the operating system and needs to be reinstalled. Windows loves trashing files to keep life exciting.
This problem is not related to the drum or toner cartridge.
Oct 10, 2009 | Konica Minolta PagePro 1350W Laser Printer
QMS Minolta 2400W doesn't print
try lifting the drum assembly, at the back of the assembly there is a fuse. replace it. hope this helps
May 25, 2009 | Minolta magicolor 2400W Laser Printer
IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Feb 25, 2009 | Konica Minolta Di1610 Copier
Konica minolta 5430dl colour printer
13D0H: Parameter Chip failure
Unplug the power cord and plug it in, then turn
OFF and ON the Power Switch.
the PWB-A may be faulty.
May 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
83 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
