Question about LG Heating & Cooling
Hi, I have a LG NEO PLASMA S18AHN SPLIT UNIT, It was already installed in our house upon us purchasing it, it would be approx 3 years old, has been pretty much running 24/7 and has been great up until recent, about 6months ago it stop and displayed the C6 error code, at this time I replace the external units motor start capacitor, it ran perfertly again for the next 4months, until it stopped again and again after reseting. When trying to run on Heat it comes straight up with "Defrost Mode" it try to start and stops after a few minutes and displays the error code. Now the only way I can get to function on Heating is to start it on "Cooling Operation" (ice flake symbol) and run it for 15mins then swap to "Heating Operation" (sun symbol) this method worked for a while also, however even this silly method has stopped working. It will only function as Cool air conditioning. I have had some many issues getting someone to service, and would prefer to replace the parts myself. Any suggestions would be greatly appreciated. Thanks Johnny.
My lg 18 000 btu split neo plasma is on heating in any mode u put it
what do u think is the problem
Posted on Sep 28, 2010
I have an LG neo plasma airconditioner and suddenly it turns off after about two minutes and it comes up with a code C5. Can anyone help please
Comms Error: check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
Dec 31, 2014 | LG Heating & Cooling
Hi I'm trying to get the air conditioning on but I can't light is flashing on the airconditioning and 12pm is shown in remote control Could u help me to sort this matter out I have three LG neo...
We have the exact same problem with our unit. Can't find solution. Any chance you have found out the cause? We also have 3 units, in 3 different rooms. The air vent's are in our garage.
Apr 07, 2011 | LG LSC121PMA Split System Air Conditioner
Have a 4horsepower neo plasma split that keeps tripping out the fuse in the meter box.have had air con guy out and he says the 14 amp fuse is not sufficient for this air con even though it has run on it...
Please note your fuse wire must be 2 to 3 times of running amps. Suppose running amps is 6.5, the fuse wire must be minimum 15 and maximum 20 amps. Always choose the maximum.
Other chances for fuse blown;
And in your a/c, If your fuse tripped as soon as compressor starts, check compressor winding with ohms. In between 2 terminal it should be equal in 3 phase compressor. In single phase compressor, SR must be the total of other two.If any huge difference it means winding weak. If any ohms reads between any terminal and grounding it means compressor grounded for which you have to replace compressor.
Hope, it's helpful?
Jan 27, 2011 | LG LS090HE Split System Air Conditioner
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
Panasonic Plasma TV problem
the cost depend upon the itmes (dameged ic, on the mother board of your t.v,)which can only bw assessed after opeing it,,,
service charge will be approx. 300 buks,
and approximately the ic's will cost, about 1200 bucks
Apr 09, 2010 | LG 42LC2D 42 in. LCD HDTV
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
Jun 19, 2008 | LG 42PC3D 42 in. Plasma Television
1/2 the picture
Hello
You will have to a tec. for this one as you have lost half of your vertical sweep.
Sorry
guy9
Jun 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
Red vertical Line on 55" Hitachi plasma
check the MAIN -Y- SUSTAIN BOARD i believe that your problem is there
good luck
caypianan@yahoo.com
Mar 16, 2008 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Heating & Cooling Logo
1,057 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
