Question about Nintendo DS Lite Console
Hi my sons ds lite keeps turning off when he is playing it, it differs all different times though,it might be on for 5 mins, it might be 3 mins or then 10 mins and we have had it charged and even played with it charging, can anyone help me with any suggections.
  • 29 Answers
It sounds like it might be an internal problem I had the same issue with my camcorder it wouldn't charge or work with the charger unfortunately if that is the problem it would have to be repared or maybe just replaced because if you send it to the company to repair its likely to cost the same to repair it then what you paid for it
Posted on Aug 25, 2010
Ds battery problem
Ok I know what has gone on here as it had happened to my DS-Lite as long as you bought a genuine DS from here in Oz or which ever country you live in and not 1 from China Etc as 99.999999% of DS consoles from China Etc are fakes
First Of all the problem is that the battery pack has failed completely the molecular structure of the battery is breaking back down into it's original state and when you recharge the battery pack it can not excite the molecules enough to completely charge as some of the molecules are dead and such will decrease the performance of your battery. You will need to buy a replacement battery pack or as it is a new console it should be covered under warranty as on a full charge on my DS Lite I can play for 15 hours+ non stop playing.
Ok the fix is very easy all you need is a small star screwdriver.
Step 1. Take the small star screwdriver and undo the screw that holds the battery compartment closed and take off the cover.
Step 2. Take out the old battery and set aside for proper disposal.
Step 3. Place the new battery in the battery compartment it should only go in 1 way.
Step 4. Replace the battery compartment door, replace the small screw and tighten.
Step 5. Charge the battery pack until light goes out.
Step 6. Play away my friend as now you should have fixed the problem.
Please Note that the time difference between consoles playing time depends on the actual ds console.
DS & DS-Lite are your better performers battery wise at up to 19 hours continuous play.
DSi to the current DSi-XL 3DS will vary from 3 to 6 hours due to the extra power needed to run the cameras etc.
Jan 25, 2013 | Nintendo DS Video Game Consoles & Games
I have a nintendo ds lite, that is older but only used a few times. My son just stuck a metal object in the back game slot while he was playing pictochat and the whole thing shut down and will not turn...
needs main fuse ( F2) repalcing
they are surface mount ( solder) fuses and small (1.3mm)
for any more help see www.dsdoctor.co.uk
may also need a game slot if pins are bent :-)
Jun 19, 2010 | Nintendo DS Lite
DS lite plays some games but not others.
Chances are its the slot- 1... Have a look at my guide i've written to see if any of the tips I suggest help, if not there is a bit on replacing the slot- 1 part. I also have a guide on taking apart the DS lite if you need it. The replacement part is readily avaliable on ebay for very little money and so long as you have soldering equipment and a steady hand you should be fine.
Slot- 1 Trouble shoot guide
DS lite dismantle guide
If you need any more help or have any questions please feel free to contact me via my profile page.
Regards.
SOD69
Feb 14, 2010 | Nintendo DS Lite Console
When my son turns on his DS Lite it comes up with the message, 'can not find DS Menu Data' and we cant play any games... are we able to re load this or something?
If you a micro sd usb card reader/writer then you can download the software of the internet here: http://r4ds.cn/download/r4_v1.18_kernel.html
Keep the game folder though it contains your games extract the to your sd card and overwrite all the files and you should be good to go. good luck!
Jan 07, 2010 | Nintendo DS Lite
My DS lite keeps Freezing
Okay if your constantly getting freezeups even after my ideas then that means the mainboard is bad, so unless your ds is under warranty and you can get the board replaced, the ds is bad.
Jul 08, 2009 | Nintendo DS Lite Console
Ds lite saying no ds card and no game pak inserted
Defecttive Slot 1
Look inside with a litte light. You will almost certainly see bend pins. You son has almost certain play with someting sharp inside the connector.
Slot1 must be replaced
Apr 21, 2009 | Nintendo DS Lite
Are all ds lite games the same
Both games are essentially the same. I don't know if they are compatible, but they could be. The game might just translate, so there would be no need to change the language. (Not that you could even if you wanted to). If your son find out differently though, each game, as I stated before, should be the same, only in different languages.
Hope it helps~
Jan 19, 2009 | Nintendo DS Lite Console
My sons nintendo keeps freezing
It sounds like there is a software reading problem. Check here www.nintendo.com to find a repair center. For here you should be able to get it repaired.
Apr 28, 2008 | Nintendo DS Lite Console
Ds disaster
this is not going to be able to be fixed you will have to return it
Mar 18, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
50 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
