Question about Cell Phones
My son has a Samsung Intensity cell phone from Telus. The slider spring on top of the 9 and 0 is displaced. It is visible from the open position; almost all of it is sticking out on top of the keyboard. How can I repair this? Thanks.
  • compumom777 Aug 25, 2010
    Not what we wanted to hear, but oh well! Thanks!
  • Cell Phones Master
  • 4,737 Answers
I am afraid if you can fix it yourself. You can't directly fix or re-seat it since there are flex cable. If you give another push, it may damage and will cost more. The best solution is to disassemble and re-assemble the handset. But for non-tech, this is not possible. You'll need the specific screwdrivers set, and you can't use the ordinary screwdriver to disassemble the unit.
I would suggest you to please call a tech or find an experienced mobile repairing guy and get it fixed. I don't mean that you can't fix it or you can't try it, but if you make a little mistakes, it'll cost more. If it's still under warranty, you can go to the retailer or to any Samsung service center, show the warranty card or purchase receipt and ask for help.
If you need further help, let me know.
(This is a risky issue, so I would not recommend you "Do It Yourself")
Good luck.
Thanks for using FixYa.
Posted on Aug 25, 2010
What do I need to do to get my phone to ring and notify me when I get a text or call?
Hi, if you go to settings, sound, you will see volumes move slider to full volume. For notifications. System default notifications. Hope this helps. Cheers.
Jul 11, 2014 | Samsung GALAXY S4
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
Codes
My son got "Samsung Galaxy Gio Gt-S5660M" from his Grandmother and she had it from Virgin mobile (in Canada). But my son has an account from Telus so it will not work, unless it is unlocked. Is there any where that I can get his phone unlocked for free, and ligit?
Thanks
May 16, 2013 | Samsung Galaxy Gio s5660
Broke the hinge on my Samsung Alias 2. Need to repair it - have the parts! I had earlier broken my LCD and took the ****** apart, and put a new LCD in. Works fine, but not all of the original screws and...
The spring goes under the little plate that is held in by two tiny screws. Its visible when the phone is open vertically with the plastic cap removed from the hinge. Hope this helps. I took my hinge apart after I dropped it and the top half came off... now it's just holding by the ribbon so I'm going to order a new hinge. Verizon is completely useless. They don't want to even know about you if you're phone isn't under warranty and I have 11 months till an upgrade...
Jun 29, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
Samsung Slyde has a spring out of place
You cant without destroying the phone. A problem like that needs to be repaired by the manufacturer (samsung), they will have to reflash the phone when they are done with the repair. Slider phones are never meant to come apart after being put together once.
Apr 14, 2010 | Samsung Rant Cell Phone
Trying to find my icon glossary on my samsung u450 intensity
To get to the Icon Glossary, open the main menu (press the center black round button) and choose the following sub-menus:
- Settings & Tools
- Phone Info (#9)
- Icon Glossary (#3)
Once you are in the Icon Glossary, you can choose which set of icons you want to see information about.
Hope that helps!
Feb 22, 2010 | Samsung SCH-U450 Cell Phone
Samsung Gravity T459 phone. Slider spring popped out of position, how do I get it back into proper location?
Nov 24, 2009 | Samsung Gravity SGH-T459 Cell Phone
My phone is puk coded a samsung j700
for teh PUK code to your simcard you need to contact yur mobile service provider and have them give you the code for your simcard.
Dec 01, 2008 | Samsung J700 Cellular Phone
Case Creaking
that creaking sound is the spring maybe its been dislocate or cut in a half. go to your nearest service center if they can replace that spring cuz' if you wont get that spring out it could get worst cuz' it could damage your flex cable.
peace!
Nov 27, 2007 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
