Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
I was disconnected how do i get reconnected...the person who came on disconnected the call...and told me the first tech would pick up now i am not able to log in...this is an emergency
    Sergeant:
  • 203 Answers
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Posted on Aug 25, 2010
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Key wont turn in the intition
Who told you that? Obviously that person has no idea what he is talking about. Makes no sense at all.
Sounds like you just need a new battery...
Sep 06, 2014 | Land Rover Range Rover Cars & Trucks
2005 Chev Uplander LT I want to stop the vents from using outside air. I want the system to only do inside venting.
I think that system is a vacumm operated in to the switches that control your heat and vents.
As simple as a hole or disconnected boot on a tiny vacuum line can cause all that.
Common problem on a GM, I have an 03 pick up with similar problems and a dealer tech friend told me about it....
Nov 04, 2013 | 2005 Chevrolet Uplander LS
Rth6500wf wi-fi series
I'm assuming you are away from the home and you do not have access to the tstat??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 11, 2017 | Heating & Cooling
I was told by a service tech that my vizio tv model VT420M has a bad main board and that the board is not available. I have spoken with 2 more service companys and told the same thing. The set is 5 days...
I just now called vizio and read your request word-for-word to their technical support person.
They have been known to fix these sets out of warranty. Although the girl said that she wasn't authorized to make that decision.
She told me to have you call this number 877-698-4946 Tomorrow when their level 3 technicians were available. She says that when you call the 1st tier tech support person will then send you one to these senior techs who can make the decision to cover it under warranty. My personal opinion is that they will take care of you. They say the "squeaky wheel gets the grease" I would go ahead and squeak. There is a link I've provided below to help.
I hope the helps,
Mark
http://www.vizio.com/index.php/support/#warrantydetails
Jan 19, 2011 | Vizio VT420M LCD TV
Start up fault
I'm not an expert at this!!
I looked up Dell Tech Faults on another pc.
Disconnect power and press on button to discharge pc. Remove side panel. Remove all USB port cables including hubs. Remove memory from the CRIMMS. Reconnect memory. Reconnect usb's. Replace panel and power cord. You can always connect to Delle Tech Support - doesn't cost.
For some reason only known to anoraks or rocket scientists--- this works and pc is restored to former glory.
Hope this works for you too.
rgds
Stuart C
Dec 13, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How many rings before call goes to voive mail
I have contacted Verizon tech support for this issue. They say it depends on where you are (what towers are responding to your incoming call) and can not be changed. I told them that Cingular could entend the ring time, not number of rings. The rude customer-no-service person told me "well, you need to go to Cingular-now AT&T". We will see what type of response I get from the letter I wrote to the President of Verizon.
Apr 03, 2008 | Casio G''zOne Type S Cellular Phone
Answerer won't pick up
i lost the book how to put numbers in memory.
Dec 08, 2007 | GE 29897GE2 Corded Phone
Reconnecting D-Link Router
well if I miss my guess, dsl has to go from the modem to an uplink on the router, cable gets plugged directy, look for a plug on the back called uplink, you can also reset the router to factory by getting a paper clip and inserting it inot the little hole in the front and press in for a few seconds, you shold see it reset by the lights
Nov 03, 2007 | Computers & Internet
UDS10 reconnection problem
Try the LS100 from www.sena.com, it has a better warranty (5yrs vs 1yr) and its about half the price of a uds-10. We've had the same experience with the four UDS-10's we have and now 3 of the four have stopped working and report the following error: "FATAL ERROR 01/Setup memory: Contact tech support". I called there tech support and the guy (Marty) actully told me that the units have exceeded their life expectency. They all failed within the first ~22 months of operation. Working in a school district we cannot afford to keep doing the same thing over and over and over again, so our next project which involves 15 building will all use the SENA LS100 product and save the district money and have way better support and warranty. Thanks goes to "tech support" person Marty at Lantronix.
Oct 26, 2007 | Lantronix (UDS-10-01) Terminal Server
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
26 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
