Hi, when I start to play the music at high volume it begins well, but within 30 seconds has dropped considerably in volume.This happens even when it's plugged in. Thanks
  • 11,800 Answers
In that case you have a faulty part inside: when the amplifying circuit is stressed by the high volume it heats up, this causes the faulty part to heat up, its resistance is increased so the volume of the signal that passes thru it drops. You must take your device apart and test the components - this is a job for a trained repairman, take it to one.
Posted on Aug 25, 2010
Volume decreases during use
Very simple. It is not a defective unit. Simply a matter of volume attenuation, hold the "function" and "grove"keys for aprox 5 seconds until a message saying vac off appears. Problem solved. Resets itself eveytime the unit is turned off .
enjoy!!!
Nov 16, 2013 | Sony RDH-GTK1i Hi-Fi Music System
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
My Altec Lansing VS4121 played excellent sound, even at high volume untill recently. A friend had borrowed them for weeks and I got them back recently. Played music to find out that sound of main woofer...
I think that some wirings inside the main woofer or the tray holding it might have loosed. It could be the speakers were accidentally dropped or anything.
You can bring it to a local store Best Buy, Staples, etc. have it checked by one of them technicians or to see if it can be put back to it's place. I'm no speakers expert but that's the only reason I could think of.
If you are comfortable opening the speaker covers and checking inside the speakers then you can also try to check for some loose parts.
Hope this helps!
May 25, 2011 | Altec Lansing VS4121 Speaker
I have a Kustom HV 100 hybrid tube amp. When I power it up, It will play normal for about 5 seconds and then the volume drops off. The preamp tube is only about 2 months old and this amp only gets played...
After the volume drops off, let the unit sit idle for a minute and then try it again. If the volume has restored for another brief period, suspect the filter caps are weak and voltage drops when you start driving the unit. In any case you need to have it serviced. Unless you can see the heater in a tube going out with vibration this may not be a DIY repair. If you see purple glow in a tube, replace it.
Apr 04, 2011 | Kustom Double Barrel 30-watt 2x12 Hybrid...
Ok, i love the tones on this amp, but for some reason, i start to play, not even on at a high volume, just like at a nice level, ill play it for like 5-8 mins and it will shut off, like the power is still...
This is a tiny amp good for practice at low volume levels. You are likely overdriving it and the power amp chip goes into thermal protect. If you volume level is much louder than a small boom box, you are driving it too hard. Best to get a bigger amp.
Jan 26, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
Squeezebox duet drops out
Hi, Did you try by Ethernet connection ? Does the problem reproduce ? If not the you might be too far away from the access point, Do you have any bandwith consuming application running on your network ? Does the problem happen with webradio and your tunes ? Thanks and have a great day J -
Dec 30, 2009 | Logitech Squeezebox Duet
Same problem, amp cuts out if volume too high
Use a multi meter,set it to 12v,turn system on use some bass.while music is playiing hold pos of multi meter to poss- neg to neg- on amp see what voltage is running at at what its dropping to it sounds more like a voltage drop problem.if you hooked it up back words u could fry unit..Have you done the big 3.what size is your alt,and what is your amps draw..
Aug 26, 2009 | Audio Players & Recorders
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Power it off and on, again
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
Ipod nano can not play songs from beginning
It droped once (it wasnt a serious drop) a month ago. After that drop it worked well. Problem occured after last sync a week ago.
Jul 24, 2008 | Apple iPod nano 3rd Generation
Shuts off after 30 seconds of Play
is the set still under warranty,if so call for service if not when you turn it on try to listen near the side of the unit for a fan noise or high voltage arc sound and do you see light on the screen or in the rear of set.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
14 people viewed this question
 Grubhead
Grubhead
