HP/Compaq 6820s will not turn on... no lights no screen flash... removed battery and tried pressing power button to remove static.. did not work..
    Sergeant:
  • 238 Answers
Check your power cord
Posted on Aug 25, 2010
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
Have a hp g60 -117us laptop after a bios flash laptop will not show a display it is only a black screen and only lights on when its turned on is power,touchpad and the first led that has a sympol of a...
Why did you flash the bios? Did you flash it with an upgraded bios that you downloaded from the HP Compaq site for your model and your operating system? When you turn on the laptop immediately start hitting the F8 Key repeatedly to see if it shows you the SAFE Mode option. If so select Safe Mode and see if it boots.
Are there any blinking lights or beeps? This is very strange. Try removing the battery and the power cord, then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and see if it boots. If it does you had a static buildup in the laptop and you released it by holding the power button for 30 seconds. If it boots, put the battery back in.
if all fails you can try to see if your system will go into System Recovery when you press the Power Button immediately hit the F10 or F11 keys repeatedly. If so you can set your system back to the way it was when your purchased it. That means you will lose all your data, documents, music, pictures and videos.
Mar 21, 2012 | HP Compaq 6735s Notebook PC KS088UTABA$247...
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
HP Compaq 2510P, 1GB Ram. Power wont come on at all. Pressing power button produces no response at all. Inserting power lead also produces no lights. Have replaced power cord and charger. Battery was...
Try this
Remove the battery from the laptop and unplug it.
Press and hold the power button for 30 seconds.
Reinsert the battery and plug the computer back in.
Try turning it on.
Many HP laptops have a built in static protection that needs to be released. This could be what happened in your case. If this reset doesn't work you will probably need to get it repaired by a technician.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 18, 2011 | HP 2510P U7600, 80GB HARD DRIVE, 2GB...
HP 6820s - Brand New battery worked for about 6 weeks. One day I noticed a solid white light (instead of green) when it was plugged in and didn't start at all. I tried taking the battery out and back in...
hold the power button on the powered down unit for 20-30 secs and try again its called a static discharge and will usually cure an issue like yours its not a sure thing but give it a try ok :)
Feb 24, 2011 | HP Compaq 6820s Notebook
Not powering up. The LED power light is just flashing when the battery is in.when the battery is taken out it remains lighted up but goes out when the power switch is pressed.
Try draining the static of the computer.
Turn off the system
remove the AC Adapter and all 3rd party devices if there is?
Remove the battery
press and hold the power button for 1 minute
then,
plugged back in the AC Adapter and battery
turned on the computer
May 19, 2010 | HP Mini 1140NR Netbook
Compaq 6820s does not turn on
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check for the issue. However, if the issue persists, then it is clear that the issue is due to internal hardware malfunction of the notebook and requires a detailed onsite diagnosis by a service technician. At this point, if your notebook is covered under HP warranty, then I suggest you to contact HP support to get the notebook repaired under warranty.
May 12, 2010 | HP Compaq 6820s Notebook
My Hp Compaq 6820s don't start when I press power button.
This simply means that the battery is dead. Pull the battery out and try to start it again (with the power adapter plugged in obviously). If it starts up, you need a new battery, if it does not start up you may have a bad power adapter or broken power jack.
Feb 26, 2010 | HP Compaq 6820s Notebook
Computers & Internet Logo
344 people viewed this question
David Payne
David Payne
