Question about Maxtor Hard Drive
My maxtor hdd is not being detected on any machine
Hi
my maxtor extranal hdd is not being detected on any machine ... not even the power light is turing on ... i need the data urgently ... pls help
  • Anonymous May 09, 2008
    I just picked up a nice Dell Pentium 4 and I suspect someone changed the jumper settings. My problem is that there is no jumper setting information on the hdd. It's a Maxtor model 91301u3. Can anyone give me a diagram. Some drives give settings and no diagram to show which side of the jumper pins to to go on. I have several drives that are down and the same problem without the installation manuals.
This is the worst website ive ever seen. All adds and no real help. Says click here for this help and its nothing but alot of other **** to click that takes you to stuff you don't need......
Posted on May 09, 2008
    Problem Solver:
  • 10 Answers
If the problem occured upon installation of a new hard drive then it may just be a jumper problem. Remember that there are two types of cables. With old type cables, jumpers must be MASTER and SLAVE (MA and SL). With newer cables, jumpers will be CS (Cable Select) for both drives. If in doubt, try both type. If Cable Select works, then position the connectors and determines which drive is C: and which is D.
Posted on May 05, 2008
    Scholar:
  • 143 Answers
To the first users question, try and hook up the drive internally, as a slave in your computer. Bypass your external case connection altogether.
To the first Guest: Use this link - http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=2851&p_created=1146083919
To the second Guest: Please repeat what you said, but in the form of a question please.
Posted on May 13, 2008
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
Pc is not detecting maxtor 3100 200 gb drive
This is very comon at times as i have also confronted with such issue on pc's having Maxtor as external drive. Here we have two things to check and understand.
1) Is the Bios Detecting this hardware. Or is it that the basic Motherboard itself is not accepting the HDD.
2) The version of OS you are running and if the pug and play is able to detect the Hardware as the second stage of detection.
Do you see any hardware detection notification when you connect the HDD or when you Start running the HDD ?
I would like you to check these which will give you a clear picture of the issue.
Else please write back.. I would like to know th OS version which you are using. The Hardware on which the HDD is connected. Motherboard Specs, and also the messages or notifcations that you might be getting while trying to connect the Hard Disk. Good Luck.
Mar 15, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Maxtor external HDD not detected by Vista
try to format it.it might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
Maxtor 3100 external drive
If the computer is connected to the power line, even if it is shutdown, you probably have in the BIOS settings the option to power it on from external sources like LAN, USB etc that is turned ON. So the USB port are still powered hence the external HDD is powered also.
Nov 19, 2017 | Maxtor Personal Storage 3100 (M01B080) 80...
Maxtor 250 GB SATA problem: Foreign disk problem
Simple you need to update your bios by downloading bios updates for you motherboard. Then it should recognise your HDD. The yellow triange just means your mboard does not have the necessary drivers to recognise the device. thanks
May 19, 2008 | Maxtor (6B250S0) (6b250s0-20pk) 250 GB...
Hdd
The first issue is how you are connected. If it is IDE or SATA. Next is to ensure that the bios settings are set to enable the corresponding connection. Next ensure you have the cords or ribbons seated properly in the drive as well as the board, ensuring the power connection is secure. Good Luck!
Jan 28, 2008 | Maxtor Hard Drive
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Maxtor Hard Drive Logo
187 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
