Question about HP Color LaserJet 2600n Printer
Just put new cartridges in my laserjet 2550 and am getting 8 blue horizontal lines across every page.
The Machine
  • 788 Answers
SOURCE: lines across printed pages
Does the line repeat, if so tell me what the distance it between repititions. I need the EXACT measurment in millimeters preferably but inches will do.
Posted on Oct 24, 2008
Binary Bob
  • 91 Answers
SOURCE: horizontal black lines across page.
Horizontal lines usually indicate a toner cartridge that is not cleaning properly.
A. If the distance between defects is 38 mm (1.5 inches), 47 mm (1.85 inches), or 94 mm (3.7 inches), the print cartridge might need to be replaced.
B. Clean the printer.
1. Clean the inside of the printer and run a cleaning page to clean the fuser.
Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
To clean the inside of the printer
1. Turn the printer off and unplug the power cord.
2. Open the top cover.
3. Remove the print cartridge.
4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge
cavity.
5. Reinstall the print cartridge and close the top cover.
6. Plug in the power cable and turn the printer on.
Cleaning the fuser:
Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of your print jobs. To ensure optimum print quality, HP recommends that you use the cleaning page every time that you
replace the print cartridge or on an automatic interval that you can set up. The cleaning procedure takes about 2.5 minutes to complete. A CLEANING message appears on the printer control panel display while the cleaning is taking place.
To run the cleaning page:
In order for the cleaning page to work correctly, print the page on copier-grade paper (not bond, heavy, or rough paper).
1. If your printer model includes a duplexer, open the rear output bin.
2. Press Menu to open the menus.
3. Use (Up button) or (Down button) to scroll to CONFIGURE DEVICE, and then press (Select button).
4. Use (Up button) or (Down button) to scroll to PRINT QUALITY, and then press (Select button).
5. Use (Up button) or (Down button) to scroll to CREATE CLEANING PAGE, and then press (Select button).
6. Follow the instructions on the cleaning page to complete the cleaning process.
7. If your printer model includes a duplexer, close the rear output bin.
If this helps resolve the problem, please post a reply. Binary Bob
Posted on Nov 28, 2008
SOURCE: HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Posted on Apr 08, 2009
  • 135 Answers
SOURCE: hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Posted on Apr 27, 2009
  • 68 Answers
SOURCE: printing with a black horizontal line across bottom of the page
Wipe the cartridge.Use cotton but dont put water on it only cotton.if you have deiones water its good to use.
Posted on May 20, 2009
Black horizontal lines
recharge(with new OPC, PCR and mag roller) or try another cartridge - if problem not solved - fuser film damaged
Jun 09, 2013 | HP LaserJet 1320 Printer
I have just replaced my cartridges and the printer is now printing with a four blue horizontal stripes across each A4 page (each about 1cm wide). Please can you help.
sounds to me like the cyan toner cartridge is defective, if you still have the old one, put it back in and see if the lines disappear. Get Paid
Jul 28, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Put the old cartridge back in. Print a page. If the lines go away, get another cartridge.
Oct 15, 2009 | HP LaserJet P3005n Printer
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
Printing with a black horizontal line across bottom of the page
May 20, 2009 | HP LaserJet 5550DN Printer
Hp laserjet 4 plus - keep getting a horizontal black line
Apr 27, 2009 | HP LaserJet 4 plus Printer
Lines across printed pages
I think you need a new cartridge.
Oct 24, 2008 | HP LaserJet 4 plus Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Unwanted Horizontal lines across the printed page
Problem is either Laser, Toner cartridge or transfer roller.
Feb 15, 2008 | HP LaserJet 4000 Printer
HP Color LaserJet 2600n Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
