Question about Microsoft Xbox 360 Console
The memory on my new Xbox 360 S has just been completely wiped of memory, The 250g of inbuilt memory doesn't even show up when i want to Save/Load, How can i fix this problem and get my memory back and/or how can i prevent this from happening again?
  • 864 Answers
Well first you would need to determine wether or not the 250gb hard drive has failed. I assume you have the new xbox 360 slim. So what you can do is remove the hard drive and reinsert it and make sure that it is firmly attached. If you do not know how you can watch this video. make sure the xbox is off and unplugged when doing this.
after that if it still doesnt work because the xbox 360 slim is new you will be able to call microsoft and get a replacement hard drive for the unit. But as i said you need to make sure the hard drive is seated correctly and not failed/DOA. If the hard drive is failed and after reseating it you still cannot get it to work let me know and i can give you instructions on how to get ahold of microsoft and get it repaired under warranty. Thanks and have a great day.
Posted on Aug 25, 2010
Is their a reset switch on the xbox 360 slim console 250g one?
For a Factory Reset, you just need to format your hard drive.
To do this, simply go to this site: http://support.xbox.com/en-GB/xbox-360/accessories/storage
Scroll down to the "Format a storage device" section and follow the steps there. This section also shows you where you can find your serial number, which is sometimes needed to complete the format.
Jul 14, 2014 | Video Game Consoles & Games
How to completely reset an xbox 360
  • First of all you must remove all disc from your console.
  • Tested with a single gamepad.
  • Turn off your device.
  • The turn it on using your gampad.Press and hold the Guide button until it turns on.
  • While the device is booting, press and hold the Y button + right trigger. The Xbox 360 logo will appears (keep the button pressed)
  • The device will restart and you'll get the Xbox 360 logo again.
  • The display settings are now reset to the defaults.
Mar 16, 2014 | Microsoft Xbox 360 Console
I have a 320gb hard drive for my Xbox and when it is inserted it doesn't show on the dashboard for memory devises
In this process your hard drive will be formatted, so back up all files to another hard drive, laptop, or be prepared to lose everything on your hard drive. After you have backed everything up, plug your hard drive into an Xbox 360 then go 'My Xbox/System Settings/Memory.Select 'USB Storage Device/Configure Now' then accept the warning.After the formatting is complete a Performance Warning box will appear, click 'OK.' Now in the 'Storage Devices' screen you should see a new option 'Memory Unit.' This shows that the formatting was successful. Disconnect your hard drive, then connect it to your laptop, load on some media (makes sure the file types are compatible), then reconnect it to your Xbox 360. Your selected media should not appear under 'Portable Device' in the Video/Music/Picture Library.
Dec 27, 2013 | Microsoft Open Box Xbox 360 320gb Hard...
Whenever i try to load a saved game from any game my xbox 360 freezes and when i try to load a saved game from fallout new vegas it told me something weird. it told me that i have downloadable content...
Sounds like your hard drive or memory chip that has a corrupt file that has affected it. Normally problems like this are only isolated to a specific game's save game files. If you have never had your console connected to xbox live then none of their updates or game patches would be present on your system; however other newer games you may have played, you might have noticed a you will need to update your system before you can play this game message on your screen. There are only 3 steps I can suggest the first is to reformat your system this will erase/revert everything to its default settings as if you're playing the console again for the first time. The 2nd would be to clear the concole cache and erase all updates. You do this method by going into system/memory/press y button/then press xx, left bumper, right bumper, xx if you do this correctly it will ask if you want to perform maintenance select yes. The 3rd option I have will erase any faulty updates which may have not completed etc. that may be causing an error, you do this by holding the synchronize button (just to left of power) then turn the power on, continue to hold the sync button until it loads completely then release. You will not receive any message or indication but any failed updates will now be removed from your system. Hope this helps, I would try these steps from 3 to 1 if I were you to, so hopefully you don't have to wipe all your saved games
Jan 14, 2011 | Microsoft Xbox 360 Console
I bought a used xbox 360 and it says to save a game I need to make a profile,but when I try to create a profile it says I need a storage device... for all the $$ this thing costs it has NO internal memory...
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.......
Click here to download repair guide
Dec 24, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
On my halo 3 game i want to go back to the campaign and find the rest of the skulls, however, when i try to load the campaign it loads to 20 percent then its goes to 0, then eventually it says...
Theres is incurrupt data on your hard drive so you have to use another hard drive or 250g memory card to navigate through the levels starting from first skull to last . it will take you about hour and half considering your skill!
Nov 24, 2010 | Microsoft Halo 3 for Xbox 360
Fallout 3 disc reading/load issues
Try going to your memory on your xbox highlight the hard drive and Press Y on the hard drive symbol and then press the following: X,X,Left Bumper, Right Bumper, X,X. then select yes this will clear any game updates they will have to be re-updated
Jan 27, 2010 | Bethesda Softworks Fallout 3 for Xbox 360
Bought fable2, knothole island DLC and my save wont load.
Was this purchased while connect to your friends connection? if so then the problems is that it was purchased with his connection and not your own
Oct 01, 2009 | Microsoft Fable 2 for Xbox 360
Froze with fable 2 after downloading
YOUR INTERNET SPEED IS IMPORTANT. GOTO SPEEDTEST.NET THAN CLICK ON THE GOLD STAR, HERES WHAT YOU NEED LESS THAN 60 PING 500MB DOWNLOAD, 546KB UPLOAD.
ONCE YOU SOLVE THIS, DOWN LOAD LIKE ALWAYS. BEFORE YOU PLAY EREASE ALL UPDATES. THAN REINSTALL UPDATES. START A NEW SAVE.
IF ALL THIS FAILS. GOTO XBOX.COM THAN SUPPORT, REPORT THE BAD DOWNLOAD. HAPPY GAMING HOPE TO SEE YOU IN GEARS OF WAR TWO.
Jul 07, 2009 | Microsoft Fable 2 for Xbox 360
Microsoft Xbox 360 Console Logo
134 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
