Monitors
Problem for Monitors
Generic problem for all Monitors
CRT Monitor and
By mrmagoo86 on May 05, 2008
At my current job I am using an older computer (Windows ME era so to speak). it Currently has Windows XP home and a Nvidia Vanta card. The problem is possibly not monitor related as I have tried two different CRT's. The only words I can use to describe this is "stretch ghosting" or "shadowing" as my IT experience is very limited.
Here is a screen cap of the visual bug:
Any ideas?
Comments:
May 05, 2008
- That is the thing. I know for a fact that my current CRT is working fine. It rand beautifully on my computer back home. I have a suspicion that it is something related to the actual computer/video card rather than the monitor.
Same Problem
Dec 20, 2008
-   same rpoblem to me with a samsng syncmaster 940N monitor, but what makes me think it is not related to the monitor is that it creates a right shadow for every object, except for the mouse -   Guest
Solution #1
posted on May 05, 2008
Somewhat Helpful)
wolftech
Rank: Master
Rating: 82%, 20 votes
The pot (variable resistor / preset on the circuit board inside the monitor) in the horizontal sync section needs cleaning, replacing & adjusting. but before that try the horizontal adj on the front panel of the monitor. Every monitor (digital or analogue) has it. Only if it doesn't clear the problem, try opening the monitor. Be careful so as not o venture too close to the EHT transformer.
Also make sure to degauze the CRT by earthing it (after switching it OFF) before toching any components inside. Also when you adjust the preset, make sure to use a highly insulated flat screw driver and wear heavily insulated rubber / PVC soled shoes because you'll have to adjust it with the monitor Powered ONonly then you'll be able to see the results. For your convenience, put a mirror in front of your monitor when you adjust the preset on the circuit board. Also make sure that you don't turn the preset very fast or put excess pressure on it as it may brea causing further damage to the circuit board.
Better still, if you don't wish to go deep into all this stuff, get it repaired by an authorised technician.
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
I have checked the refresh rate through the vga port using a CRT, and it is set to 60 Hertz. The... (More)
Answer
How do I set brightness, contrast, etc. with my AcerView 76e? I see the buttons P, left arrow, right... (More)
Answer
I need an updated driver for my starlogic MJ9BBK monitor.
Answer
My dell E172FP monitor starts up but only stays on for a second or two. Tower works. Can this be... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitors Experts
Top Computer & Laptop Repairmen
in , AR
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
