Question about Audiovox PVS21090 9" TV/DVD Combo
Can't get the channels to come in on my Audiovox PVS21090 9" TV/DVD Combo. The channel came in good the first time I hooked up the TV. Now it just read no signal. I have a RCA indoor antenna. What indoor antenna is best to use?
  • 78 Answers
SOURCE: no cable signal
somewhere in the tv's menu (or a button on the tv or remote) there should be a way to change the tuner setting from antenna to cable. you may have to make the tv run through autotune. a switch or button may be on the back of the set, close to the
cable connector.
Posted on May 02, 2008
natenash7986
  • 53 Answers
SOURCE: Don't have all the channels on my Audiovox Xpress R
i would send the unit back to where u got it. i have ran into this before and the unit was sent back to xm and they replaced it call xm and see what they can do for you
Posted on Aug 07, 2008
  • 1779 Answers
SOURCE: Need a remote that works for TV and DVD player
Go to Remotes.com and put your model # in, they do have the original for $30.00
Posted on Feb 26, 2009
  • 1297 Answers
SOURCE: my audiovox remote will not turn on tv or change
Try put again the batteries.A very simply and efficiently mode to see the remote control is work or not to tested of pressed taste next on radio posted on FM or MW.
Posted on Aug 21, 2009
SOURCE: Can only receive cable channels 2 through 13;
Turn the unit off, push the setup button 3 times. Press the seek left/right to switch between cable / antenna tuner modes. When cable is selected, press the channel up/down to switch between cable modes. When the unit turns back on, it will rescan for channels.
Posted on Dec 29, 2009
What channel does the tv need to be on for the hmdi cable to get a signal?
It's not a channel. You should select the input to TV to HDMI. Refer its user manual, please.
Electro help
Sep 21, 2014 | GPX KCL8807DT TV/DVD Combo
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
Aug 04, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Is Audiovox VE1020 HDTV compliant?
Audiovox VE1020 is not a digital set. To see digital broadcast you will need another digital reciever or a long lead to connect to your existing one.
This set does not have very good reviews either.
Hope that helps!
Jun 06, 2008 | Audiovox VE1020 10.2 in. TV/DVD Combo
Connecting VCR/DVD combo to TV
If that is the only input that the tv has it's still usable. Just plug the Cable TV or antenna cable into the DVD/VCR coaxial input labeled "in" (instead of the TV's) and hook one from the DVD/VCR's "out" to the "in" on the tv. Turn the TV to channel 3 or 4 (depends on DVD/VCR settings) and use the built in TV tuner on the DVD/VCR to change channels.
Sep 20, 2007 | Televison & Video
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Receiving tv programs
In the menu theres a channel set up mode. You want to switch from antenna to cable mode, then do an auto search. Then all your cable channels will come in. Your going to need the original remote to go into the correct menu. good Luck
Aug 25, 2006 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Audiovox PVS21090 9" TV/DVD Combo Logo
41 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
