Question about Canon CanoScan LiDE 25 Flatbed Scanner
Opening Canoscan case
Good Day,
I have a newish Canoscan N6700ULide. The internal ribbon cable has kinked and is threatning to break. How do I get the scanner open to repair the cable?
many thanks,
Dion Krige
Johannesburg
SouthAfrica
  • dionkrige May 10, 2008
    Hi Shaggy,
    Many thanks...the 6700U doesnt have screws, just glued plastic strips down the side. Managed to prise them off and did a 100% successful repair.
    Many thanks for the assistance!!
    Dion
    Genius:
  • 1,224 Answers
Screws on bottom ease the case off fix ribbon there under the rubber stops then once open your going to want to seal galss back down i recommend jb weld on edges to hold glass in if u dont secure glass when open a month down the road the glass will pop down i had my scanner 16 years since jb welding the glass down you only spot jb weld the glass though
Posted on May 10, 2008
Computer goes black if we move it
Do you mean that the screen blacks out? It is possible that the ribbon cable that internally connects the display to the main board of the laptop is loose, try holding the display steady, and do not allow it to move, if that prevents the screen blacking out, you have a loose cable. If you are still under warranty, then you should be able to get it replaced by an official Toshiba dealer, but that depends on whether this was caused by accidental damage, etc. (Toshiba support should tell you the details). If you aren't under warranty, you can attempt a DIY repair by opening up the laptop and locating the ribbon cable, but if you are uncomfortable, and not confident about that, then you should take it to Toshiba, as DIY has a chance of worsening the problem in some cases.
Jul 05, 2011 | Toshiba Computers & Internet
Speedometer bounces around on my 1972 chevrolet pickup and makes a noise within the cable where it connects on the cluster..
There is a cable inside the sheath of you speedometer cable that looks like a long tightly wound spring. It may be about to fail. You can remove it and get a new one. If it can not all be removed from the top - you will have to undo the cable at the transmission to remove it. Be sure you get all of it out. When you reinstall the new cable be sure and lube it well. I use motorcycle chain oil - it is water proof and lasts a long time. Let me know if this helps. Thanks. (nice a '72 hope it is realy good shape)
Dec 24, 2010 | 1972 Chevrolet Corvette
My computer says that the hard drive is not inserted correctly.what do I do
Open your computer casing and look for the ribbon cable attached to your hard disk drive and motherboard. Unplug the ribbon cable from the motherboard and hard disk drive. Then put it back again the cable and observe, if the problem is still the same. Next part is to unplug the ribbon cable from motherboard and hard disk drive and observe for the sound comes from your hard drive. Try also switching your ribbon cable into another IDE ports.Normal hard disk drive usually have a normal sound but the defective hard disk drive have a mechanical noisy sound. Have a good day.
Dec 02, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
Will not stop opening and closing
sounds like a logic glitch . the last time i saw this the customer tried resetting. it worked ok for a little while but he ended up buying a new deck because the problem never went away
Feb 08, 2010 | Dual XD-7500 CD Player
Left & right arrow keys not working.
Try to connect an external keyboard, see if that one works. If it does, then the problem is most likely a loose ribbon cable from the internal keyboard to the motherboard (especially if you recently installed a new one) - also, while you are examining the cable, look for any tears, cuts, or kinks in the cable. Good luck!
May 10, 2009 | Dell Latitude CPI-D Notebook
Canon i9100 Printer - damaged carriage ribbon cable
Contact Canon support by E-mail. Or Solution: Ordering parts for your product
Ordering Replacement PartsCanon does not sell internal replacement parts on-line. Parts are available exclusively by calling the Canon customer support center (the contact information is listed below).
However genuine Canon supplies and accessories are available for purchase on-line at the Canon eStore. Before calling Canon, please check the Canon eStore to ensure that the item you need is not an accessory that is available in our on-line store.
To order an internal replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance.
For your information, below are examples of what constitutes an internal part Vs. a supply / accessory:
Examples of Parts:
  • Print Heads
  • Printer Paper Trays
  • Printer Paper Guides
  • Camera Battery Doors
  • Parts Only Assessable By Taking the Product Apart
Examples of Supplies / Accessories:
  • Ink Tanks
  • Battery Packs & Chargers
  • Most Power Adapters and Connecting Cables
  • Shoulder / Neck Straps
  • Bags and Cases
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=8738#SupportDetailAct
Feb 01, 2009 | Canon i9100 InkJet Photo Printer
Changing the ribbon
I just had the same problem today except I needed open because of a paper jam. Anyways, I started by using a philips head screwdriver and pried by where the plug is and worked my way around. The cover is held on by the screws on the bottom and some tabs inside. You kind of have to pull if open as it is very stubborn. Good luck!
Oct 14, 2008 | Casio DR-250HD Calculator
LCD screen replacement
www.buy202.com they have them for under 40 with free shipping
Sep 08, 2008 | Kodak EasyShare M853 Digital Camera
Ds shell
you are best watching a dismatling video on youtube, here is a good on but sound is foreign: http://www.youtube.com/watch?v=-dHtv9DA94g&eurl=http://www.dsfanboy.com/2006/02/20/dismantle-your-ds-in-13-minutes
A few tips:
Take care with those speakers, the connectors are very sensitive and the wires can easily break.
Take care with the screen ribbon cables and connectors on the board, the two big ribbons have connector that lift up the little ones slide outwards.
the hinge cover has a little screw near the ribbon cable dont forgot to take that off so you can extract the ribbon through the case slot and don't forgot to replace that on your new case before putting it all back together.
on the top screen the ribbon cable may be covered by a bit of sticky foam, just peal that away carefully to access the ribbon.
Watch you dont loose any buttons by tipping the case when dismantling.
In general just take care and dont attempt to turn it on whilst in bits, you could short the screen on the board and blow a fuse.
Good luck...
Jun 04, 2008 | Nintendo DS Console
No sound on nintendo ds. How do I fix?
The speakers are wired from the ribbon cable that also provides the top screen illumination. That cable gets plenty of abuse by opening & closing the DS. Could be a break/tear in that ribbon cable. Does either speaker work? both are bad? If neither work, it's a rather involved process to fix yourself (soldering, etc). You can mail it away for service. Call Nintendo to get a quote.
Apr 26, 2008 | Nintendo DS Console
Canon CanoScan LiDE 25 Flatbed Scanner Logo
426 people viewed this question
old marine
old marine
