Question about Nokia 6230
Security code nothing works if i press # it has th e same function as ok
  • shahirah May 17, 2008
    my phone cant accept the code i had change than it will not access it
Your keypad was grounded, try to open your phone and check if there was a moist. clean it and dry it using hair blower. good lack
Posted on Jun 30, 2008
I forgot my security code for my kenwood kvt-514
Hello
To deactivate the security code,
Display the Security Code Setup Screen.
Start to cancel a registrationof the security code.
Enter a new security code. Input a four digit number as security code.
Register your security code.
Now the previous security code is cleared. OK.
Dec 03, 2011 | Kenwood KVT-514 Car DVD Player
Code for Sky remote for AlbaALCD15DVD2 tv Thanks TH
Hello
Sky remote codes to check with Alba TV are:
037 065 246 399 263 064 446 609 275 077 515 244 398 239 400 459 191 383 607
696
705
742
471
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 to 3 and work through all the relevant 3 digit numbers from the Sky Plus remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Sep 20, 2011 | Televison & Video
Security code nokia 6288..bought it but does not work in my country pls help me th the code
Default security code of Nokia is 12345 and if they have any country wise changes in security code then please refer to your manual book which comes with the phone.
if nothing work then go and install new firmware and unlock them.
vote me if found helpful.
Aug 10, 2011 | Nokia 6288 Cellular Phone
How to unlock cell phone
lock application
Lock phone applications:
Find it: s >wSettings > Security
> Lock Application
When prompted, enter the unlock code and
press Ok. Then scroll to the application you
wish to lock and press Change.
change unlock and security codes
> New Passwords > Unlock Code or Security Code
control access to location function
Set up a location code to control access to
the Location function (see “AGPS & your
location” on page 59):
> New Passwords > Location Code
Apr 25, 2010 | Motorola Mobility KRZR K1 Cellular Phone
Canon image runner 4570 in error code E000100-0001
Ok here is how to reset the error if that doesn't work... you really need to call a tech... you are going to need some serious work done on your copier... ok... here are the instructions
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
Dec 21, 2009 | Canon ImageRUNNER 3570 Copier/Printer
6300 master code
Hi the master code only works if the phone is asking for the code when you switch it on and it will also only work if the code has not been entered wrong more than 5 times ok enter this code
1626673066
this will give you acess to the phone and will also reset the security code to what it was when new ok.
Let me know if you need further assistance
Mar 19, 2008 | Nokia 6300 Cellular Phone
Security code for 6133
Open phone, don't go to any menus. Dial *#7780# and press green send button. It will say if you would like to restore factory settings and say yes. Then it asks for a code. This is when you put 12345 and then press OK. This should help because it did for me.
GOOD LUCK!!
Jan 21, 2008 | Nokia 6133 Cellular Phone
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
LG CU400
Locking and Unlocking the Device: FOR LG CU 400
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and select Lock Handset.
  5. Select desired option:
    • When Power On
    • When Smartchip Changed
    • Immediately
    • Off
  6. Enter the Security Code, press OK.
    NOTE: The default security code is 0000.
Setting the PIN Code:
  3. Scroll to and select PIN Code Request.
  4. Scroll to and select On.
  5. Enter the PIN code, press OK.
    NOTE: Default PIN code is 1111.
Changing the Security Code:
  3. Scroll to and select Change Codes.
  4. Scroll to and select Security Code.
  5. Enter the current Security Code, press OK.
  6. Enter in the New security code, press OK.
  7. Confirm Security Code, press OK.
IMPORTANT: If the incorrect lock code is entered more than 3 times the phone will display "ENTER PUK". If this message is displayed contact Customer Care.
Nov 28, 2007 | LG CU400 Cellular Phone
Nokia 6230 Logo
20 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
