Question about Fujitsu 24R1 Air Conditioner
I have vacuumed and cleaned out the air filters and the deodorizing filter, but still get the moldy smell whenever the a/c is turned on. What else needs to be done to eliminate this awful smell?
  • 674 Answers
Try cleaning the evaporator coil. You can buy some cleaner that doesn't have to be rinsed off at a heating and air supply. This should help.
Posted on Aug 25, 2010
Fishy smell comes from machine during use what's the problem and how do I solve I have changed filter and rinsed out tanks
If you are sure it is not in the filters (there will probably be more than 1) and the tank/dust collector is clean, then I would make sure all of the tubes are clean and totally debris free.
The smell may linger a while and fade over time if you have cleaned it as best as you can, so in the meantime maybe put some kind if deodorizer in the outlet filter.
HTH
Mar 24, 2016 | Filter Vacuums
How many cabin air filters do I need to replace in a 2005 Grand Cherokee Limited?
1 filter. You could also try spraying deodorizer into the cabin air system intake near the hood and windshield from the exterior.
Jul 14, 2014 | 2003 Jeep Grand Cherokee
Dyson filter smells like mold after washing
Patry816:
It might not be the filter! The hose, canister and suction vanes on the motor also can cause that smell!!
Jan 06, 2013 | Dyson DC23 Animal Vacuum
Sour odor
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home. It will smell like the home that it was in, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air in your home, also.
Replace the hepa filter first thing.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jun 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Moldy smell in washer after using it.
add about 4 cups of bleach to the washer run through the hottest wash cycle possible. allow to air dry overnight. then add 4 cups plain white vinegar and run through hottest cycles again. to ensure this doesn't happen again remove all wet item as soon as possible. any clothing items that smell musty can also be run through a vinegar wash using about 1/2 cup in the softener compartmen.
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Dog smell after cleaning
This is an inherent problem with bagless vacuums. The filter(s) will absorb odors and odors will get trapped in places that you cannot clean. This is why I always recommend bagged units. They are easier to clean and the odors go out with the bag. About the only thing you can do is put a deodorizer in the machine and keep the filter clean. Be careful not to use petroleum based deodorizers as they can affect the plastic.
Feb 17, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Odor blowing from filter area
It sounds like you will need to first clean it very well if you haven't yet and then most likely the problem is the rear hepa filter is ruined due to having sucked up what you did and gotten some on the filter.
Each time you turn on the machine hot air is blown through it and can smell very foul. I had gotten mine wet once from the machine tipping over and had to replace it because it started smelling moldy. Very easy job to do and its about 25 bucks and you can find them on ebay or other places. Hope this helps
Aug 12, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Fujitsu 24R1 Air Conditioner Logo
212 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
