Question about Microsoft Xbox 360 Console
360 problem my 360 has recently stopped loading all my games except for PGR3. keeps telling me to play the game i must put the disk into an xbox 360. the games work fine on my friends 360 so dont think it's the disks. any help please.
  • 1 more comment
  • kris9128 May 05, 2008
    wich lable do you mean mate. bit new to 360
    thank you mate. will get it looked at asap. still loads pgr3 first time tho,
    warranty has expired, unfortunatly. it plays dvd's just fine and will load PGR3 first time. have tried lens cleaner but no difference.
    Master:
  • 788 Answers
This message comes up when the console identifies a game DVD as a movie DVD. You will see the same message if you put your game DVD into a standard DVD player.
Most people have been having their consoles replaced for this issue, hopefully yours is under warranty, you should get in contact with Microsoft.
Check out these two threads on the subject: http://www.avforums.com/forums/showthread.php?t=430397
and
http://www.avforums.com/forums/showthread.php?t=426104
Posted on May 05, 2008
  • 2,326 Answers
You might want to try using a lens cleaner first before you decide to get the lens replace. If the lens cleaner does not work it will be time to replace the laser lens, it might not be a DIY.
Let me know if you need further assistance.
    Genius:
  • 3,422 Answers
"insert DVD in a 360" problem - the laser is shot and so the drive needs replacing. I strongly sugggest you to get it repaired or just replace it if it is still under warranty.
Goodluck,
Please don't forget to rate the solution.
    Brigadier General:
  • 3,614 Answers
Can you please tell us the label of the disc..
& we may know if this problem happen on all the games you played..?
thank you
I put a game in the xbox 360 to let it load up at the main xbox 360 screen where you can mess with your profile and the game loaded up and when I clicked the game to load up so i could play it it said I...
Make sure the disk is clean.
Reinsert and try again.
If it does not try to update again and it tries play the game but does not work and it is not because it cannot read the disk then go to the settings, hard drive and go to "System Cache" and delete.
This will delete all temporary files. Which means all small updates for games will be deleted. I reccomend doing this as it may be an error due to the update being stopped halfway through therefore being unfinished. So the xbox may recognise that the update has been installed but because it is unfinished then it may not be able to start the game.
If this still does not work try disconnecting from the internet as it will not ask for an update and you will be able to play the game without it. If this does not work and the game does not play it may be a problem with the disk.
First I would suggest playing the disk in a friend's xbox. If it still doesn't work, take the disk back to the shop and get it replaced.
Mar 02, 2011 | Video Game Consoles & Games
How do i clean xbox 360 len?, xbox keeps saying my disk needs cleaning, the disk is spot-less, after 3/4 of an hour (appox), it loads the game. Thanks.
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
You can use the recommended guide to fix this and get back to gaming.
Feb 24, 2010 | Microsoft Xbox 360 Console
I have an xbox 360 and it will play the disk but no sound i tryed every thing to the AV cables to buying a console eye cleaner disk and it still dont play sound im thimking its my sound card but im not...
What kind of cables are you using? What are the colors of the cables?
Have you tried your friends AV cables?
How many more discs experiences this?
- Try your friend's xbox360 console's settings to your console.
Nov 24, 2009 | Microsoft Xbox 360 Console
My 360 plays all games except this one
Check if your new cd has an uneven surface , like it's bent . Is the grinding noise occuring for all the other games ?, if yes you should check your Xbox's CD reader head .
Oct 04, 2009 | Microsoft Halo 3 for Xbox 360
My xbox 360 only pays old games(like pgr3) and not new games(like need for speed shift)
The laser in your XBox 360 is probably going out. When lasers start to fail, the first discs that stop reading are newer, dual layer, discs. Single layer discs will still read. As the laser wears out, single layer DVDs will stop reading but CDs will continue to read. Eventually, everything will stop reading and the laser will die.
You can find lasers for the XBox 360 all over the internet. Installing them isn't easy though.
Oct 03, 2009 | Microsoft Xbox 360 Console
Saints row 2 loading problem
try and save the game to your Xbox360 harddrive(HDD) and then run it off that?
Sep 26, 2009 | THQ Saints Row for Xbox 360
I cant play games
This message sometimes comes up if you have copied the game to the 360`s hard drive , the game will only be playable if it is in the DVD drive as the 360 needs to know if you still own that game . It will spin the drive to see if you still own it and then load it off the hard Drive .
Sep 08, 2009 | Microsoft Xbox 360 Console
Error disk reading Xbox 360
You can try a 3rd game and see if it loads and if so then there is a problem with PGR3 and not with game. Also clean with alcohol and try again
Aug 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
