Question about Airtemp B6D30E7A Air Conditioner
Airtemp rooftop package AC unit M/N- RT-3130-01, what is the capacity of this unit
RT stands for Rooftop
3 stands for 3 Phase, 1 for single compressor and the remaining 30 stands for 30kW nominal cooling.
Posted on Sep 18, 2012
  • toddsteele72
    toddsteele72 Sep 20, 2012
    Sorry, I need to make a correction.
  • toddsteele72
    RT is for Roof Top...first 3 is for 3 Phase, the 1 is actually for COOLING ONLY and as previously stated, the final 2 numbers are for nominal capacity in kW. If you see a 2 as the 2nd number, it means HEAT/COOL.
  • 587 Answers
SOURCE: We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 127 Answers
SOURCE: coleman rooftop a/c unit is fried? i plugged my
If there Air Conditioner is wall thermostat controlled, then take the front cover off the thermostat and check the fuse. If the fuse is ok, then take the inside cover of the AC down and pull down the control box that is mounted in the intake section of the AC. It is held on with two wing nuts. Remove the cover and observe the relays and the incoming AC wiring. Make sure that none of this is burnt. If all looks ok, turn power on and turn the thermostat to High Cool and check if you can hear the relay click inside the control unit. If not, then check to see if the thermostat has 12V going to it. Start there and see how that goes.
If it is controlled by the ceiling mount t-stat and selector switch. Remove the inner shroud and check the incoming AC wires for OK. If they look ok then check the selector switch and the thermostat.
The Refer has protection from this. Depending on which refer you have (Dometic or Norcold), the process is a tad different. If it is a dometic, go to the outside of the coach and remove the access panel on the rear of the refer. Remove the black cover from the control board (lower left side) and check to make sure that the 120V fuse is good (You will need an ohmmeter to check). If it is fine the check to see if you have power going into the 12V block at the very bottom, rear of the refer. If there is 12V there, then check the plug that the Refer is plugged into for 120V. If none, check the GFCI circuit in either the bathroom of the kitchen. If tripped you will have no power to fridge. Start there and then we will move forward.
Basic same checks for a norcold, board is harder to remove as you have remove wires. Mark and remember where they go.
Hope this helps,
Jeff
Posted on Jun 30, 2009
  • 59 Answers
SOURCE: How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Posted on Apr 21, 2010
SOURCE: I was loking for the Capacity of an Airtemp
its a nominal 41.5kWr (has 2 x 6.5 hp mitsubushi compressors JH519YEP)
Posted on May 17, 2010
  • 1768 Answers
SOURCE: I cannot read the model of Package AC with electric heat strips,
Here is a site that may provide you with all that information.
http://www.furnacecompare.com/air-conditioners/frigidaire/P3RA-036K.html
Posted on Jun 18, 2010
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
I installed my new unit this summer and the ac worked fine, now the heater does not work
frist check that the thermostat and the mood is in right positions then check that thermostat give signal to Htr.if Htr is right ohms
Nov 11, 2013 | Goodman Manufacturing Goodman...
AC Wont stop running.
a defective thermostat thats all
Jun 02, 2013 | Dometic Rooftop RV Air Conditioner
Dimensions
by dimensions do you mean the physical size or the capacity in BTUH? you should get a machine that will fit in your window and if the A/C cooled the room ok get one that matches the BTUH output.
Jun 02, 2010 | Airtemp B3Q06F2A Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Airtemp B6D30E7A Air Conditioner Logo
484 people viewed this question
Top Airtemp Heating & Cooling Experts
Tim Whalen
Mike Squire
Mike
Are you an Airtemp Heating and Cooling Expert? Answer questions, earn points and help others
