Question about Plumbing
Fitted new hudson reed crosshead bath mixer tap, the water flow from the shower is considerably lower than with the old mixer tap, is there anything i can do to resolve this?
  • 128 Answers
Did you get any soilder in the valve was the valve apart when soildering that could possibly your problem
Posted on Aug 25, 2010
Grotherm 800 bath shower mixer just fitted with pumped feed but not giving any pressure
Hello Mark Bentley,
In California... (MY OPINION... every bit)
It is called "social engineering".
FOR More than 25 years... before "the drought)
and without public knowledge MY state mandated
water flow restriction at the VALVES
Although the shower VALVES... were MAUFACTURED
prepared for 1/2 inch PIPE FITTINGS... FINAL
MACHINING severely reduced the holes through
the side of a typical body... were smaller than the
EASILY altered WATER RESRICTERS IN EVERY
shower-head & faucet NOW sold in CALIFORNIA...
Back then... That was 1½ or 2½ GPM
water restriction... (I don't remember which).
It was part of the VALVES CONTRUCTION...
I am PRETTY SURE you are going to have to call
GROHE and find out if there is ANYTHING they
can recommend... now that your VALVES
are installed & finished over... What can increase the
allowed water FLOW...
Only a traveling DENTIST would have the tool
to work from the INSIDE of the valve...
Just my opinion...
Carnac the Magnificent
Jun 13, 2017 | Home
I have a bath shower mixer with a shower set. I cannot get water to come out of the bath tap, only for the shower head. The fitting in the middle if the taps will not stay down.
Go right away back for replace if there is warranty in between 8 days, if not then there should often a simple mixer maintenance set for sale for the brand and exact model mix faucet. often from simple plastic if its an older (mostly solid) mixfaucet then only to put it 24 hours in a bucket of vinegar or descaling agent.
Mar 01, 2017 | Home
Bensham tap not switching shower flow to bath
If your Bensham tap not switching shower flow to bath then you should check the connection first and if still the problem get not solved then you should hire a professional to fix this problem.
Feb 04, 2013 | Home
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
Hi Have a hudson reed kia twin valve shower - fab! But recently taking forever for the hot water to come through. Don't think it's the boier as the hot water comes through quickly everywhere else...
with out a water circulator every thing takes time ----------- sounds like the thermostats going bad you do have a 10 year warranty on this faucet type in your browser hudson reed kia faucet
Jan 18, 2011 | Home
I have mixer taps on my bath, hot water tap doesn't work
you may just have to replace the hot/cold stem
Mar 11, 2010 | Home
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Plumbing Logo
194 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
