Question about Brother Office Equipment & Supplies
How to change ribbon - Brother Office Equipment & Supplies
  • Anonymous Aug 07, 2008
    I Have Bother Fax-878-MC witno instuctions onchanging th ribbon, pleae hlp
What are the steps of changing a ribbon to a printer?
Posted on Apr 30, 2009
The problem is paper jam
Posted on Jun 04, 2008
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
Changing the ribbon
There are many ribbons on desktop computers
Hard drive ribbon ide cables , floopy drive ribbon cables cd/dvd drive ribbon cables .keyboard ribbon cables , lcd screen ribbon cables......
IDE Hard Drive Connectors http://www.youtube.com/watch?v=4inX3nC6M1E
Mar 07, 2013 | Computers & Internet
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
I have a Zebra 105 SL, I have the ribbon installed but the printer tells me that the ribbon is out. I've tried changing the ribbon and labels out but as soon as I power it back up and try printing again...
Calibrate the printer from the setup menu.
You'll (1) Load the label backing with the ribbon (2) remove the ribbon - just shove it to the right, out of the way of the ribbon sensor (3) reload the label and ribbon.
The printer will run a number of labels out.
Feb 16, 2011 | Zebra 105SL Thermal Label Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
N95
hi friend,
go to website
www.sparepartsformobiles.co.uk/mobile_phone_spare_parts.asp?...%20ribbon%20with%20keypad...
Then consider changing the Flexi PCB (ribbon). This is a common failure as the ribbon can suffer wear as the phone slider opens and shuts. Eventually the ribbons become worn and often this results in a screen failure. Changing the ribbon can cure this in most cases... We advise that a new ribbon is added when the screen is changed it’s a good way to service this type of part. So if you do have a screen problem including a screen failure then consider changing this part before you spend good money on a screen.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Nokia N95 Cellular Phone
Sony UP-DR150 4x6 "ribbon error"
The black spool of the ribbon has a built in chip, If that chip is damaged it renders the ribbon unuseable. Be very careful if you take out party used ribbons and re insert them later.
Dec 15, 2008 | Sony UPDR150 Thermal Photo Printer
Hot to change ribbon on sony m8800
Its not too hard to change. I have done this once before. Open main unit. Remove cd mech to get to the other end of the ribbon. Remove this end first. Manually rotate the motor worm gear until screws on head unit are visible. Install ribbon in head unit then main unit. Make sure the ribbon contacts and ribbon are positioned/routed the same way. Rotate that motor (end to end) again to see if the ribbon hangs up anywhere.
Nov 05, 2007 | Sony CDX-M8800 CD Player
360 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
