MSI Laptop Error- 0xoooooe9 "This error can be caused by unplugging a removeable storage device blah blah blah.... it wont get off the error screen and start windos. What do i do?
  • 12,061 Answers
Ok, this error has occurred and will continue to occur, because a drive was removed, from the system, before data that was meant to be written/read, to/from the "Drive" was completed.
The only way around this is to reconnect the device so it can Finish what it is doing. If you have been using a USB drive, then you need to reintroduce that back to the system.
Now if you cannot, do this, then I would suggest that you simply perform a system restore. That will hopefully restore you system to where it was BEFORE this all happened.
Before is a a link how to do the system restore.
support.microsoft.com/kb/306084
Posted on Aug 25, 2010
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
    Depending on the changes you made, some solutions might include:
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
Windows Boot Manager message: Windows encountered a problem communicating w/a device connected to your computer. Error may be caused by unplugging a removable storage device such as an external USB Drive...
Make sure there is nothing attached to the laptop,remove all devices like keyboard,mouse, flash drives and retry. If still having same error flip the laptop over and remove the battery and open up the 2 other compartments that have a screw holding them. One holds the memory modules and the other the hard drive, check and re seat all connections, then try again. If you still have the same error your hard drive is most likely failing,
Thanks for using FixYa
Jul 23, 2011 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
Dropped laptop off of couch onto floor apprx 18in. Computer locked up. unplugged and removed battery for five to ten minutes. started to boot and gives me "Windows has encountered a problem...
If your hard drive was running at the time you dropped it, your hard drive might have crashed. Sorry to tell you this buy you most probably need to replace the hard drive.
Apr 11, 2011 | Computers & Internet
I have a Toshiba Satellite A135-S2276 laptop running Windows Vista. The laptop was dropped from about 12 inches by my child. When I opened Explorer, it was acting funny, so I rebooted. The main Toshiba...
Windows is corrupted beyond repair, you need to reinstall it. For the recovery discs, call Toshiba at 800-457-7777. They will want to know the computer's serial number and a credit card number.
Sep 09, 2010 | Computers & Internet
Xp not install in compaq presario cq50 139wm
In Windows XP, The STOP: 0×0000007B: error often occurs if you move a hard drive that contains Windows XP to another computer or if you have just installed a newmotherboard or drive controller. This error occurs in these cases because your registry does not contain driver entries for the current motherboards drive controller. So in effect, the device driver that Windows XP is loading from the registry will not work with the new drive controller.
Fixing the STOP: 0×0000007B: Error:
The easiest approach to fixing the error is to locate download and install the latest hard drive controller driver for your motherboard. In many cases the driver in question controls a ATA or SATA device.
There are other problems including viruses that can cause this error and information regarding these causes can be found HERE
Jan 01, 2010 | Computers & Internet
Need a system recovery? Tried the F8 method--doesn't work! Help!
Just unplug the hard drive cable and plug it again. otherwise if problematic replace the cable.
Apr 24, 2009 | Gateway GT5404 PC Desktop
Compaq Presario 2800 boot error
tried F8rapair your computer and startup repair and system restore...
Jan 23, 2009 | Compaq Presario Notebook
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
