Question about Polycom VSX 7000 Video Conference
I have connected a polycom vsx7000 to a TV. the camera output i get is black and white. could some one kindly help me on this
4 Suggested Answers
SOURCE: viewstation FX - connection issue
it is your firewall.
Posted on Apr 20, 2008
  • 10 Answers
SOURCE: Can not able to dial out any number from Polycom VSX 7000.
Check out the following things:-
1. When dialing a ISDN number, be sure that the call preference has not been set to IP H.323 on the home screen just below the dialing field.
2. Check with your service provider that outwards dialling have been enabled on the lines provided to you.
Posted on Apr 02, 2009
SOURCE: polycom VSX7000 video camera
Hi there:
This happened to my VSX camera and the fix was simple. I have a VSX 8000 so if your camera is different then mine you might not be able to follow this. This might not work for you but, try it. On the back of the camera you'll find a small little screw. Keep the system on and watch your cameras image. Start to loosen the screw. You'll only have to do it a little bit and the camera should start to focus again. Tighten the screw up (maybe not as tight as it was before) and test to see if it's auto focusing. Also....manually moving the camera around while it was on could have helped as well. Finally....I did not have to do this but if it is not working simply by loosening the screw...I would take it all the way out and remove the little cover or hatch that it holds. Poke around in there a little bit to see if the the focus motor unsticks itself. If you are still under warranty (I was not) don't do this...call the vendor who sold it to you.
Mine's working great now simply by loosening this little screw and tightening it back up.
Posted on Jan 14, 2010
My videocon tv having automatically av/tv switching problem what is its solution
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 09, 2014 | Polycom VSX7000 Videoconferencing System...
No AGC output,not normal colour
Pls can you ellaborate more on the problem...
Apr 12, 2014 | Polycom VSX7000 Videoconferencing System...
Videocon TV model No. CTVVBN14MGF-CNA goes in stand by mode after 5 minutes. Please suggest me a solution.
There should be some loose solder terminals at its main power regulator section. Resolder all the suspected solder terminals there, by applying a little more solder. Check the solder terminals at the horizontal output stage too. The fault is with loose solder terminals itself.
Sep 07, 2013 | Polycom VSX7000 Videoconferencing System...
Polycom VSX7000, do you have to suscribe to Polycom to get anything on screen. I get a bootup sound, but that is it.
No, you do not need to subscribe. Are you sure your a/v cables are connected properly? You might also check on your video source and make sure you are in the correct source.
Jan 18, 2011 | Polycom VSX 7000 Video Conference
My VSX 7000S does not recognize the microphone. It is connected to VSX\r\ncamera by the brown RJ11 cable with ferrite end to the camera but no sound is picked up and system status indicates "no...
You need to go into the audio settings via
Admin Settings
Audio Settings
and make sure Enable Polycom Microphone is checked off.
Reboot and see if your microphone is recognized.
Jan 13, 2011 | Polycom VSX7000 Videoconferencing System...
Dec 03, 2008 | Polycom VSX 7000 Video Conference
Can't get to the home screen
I've just solved that problem in the VSX 7000 of my girlfriend's Job.
Your VSX7000 has at least 4 video outputs, 1 for VGA and Supervideo 1 and Supervideo 2.
Firstly you should try VGA connector, because the main menu may be there, so you could change the configuracion.
If you can't see main screen in any of the output connectors you'll have to use the http tool.
In your internet browser enter the camera IP address, and you'll get the Web Interface of the VSX7000.
It will prompt you for user & password, the default options are "Admin" and your VSX7000 serial number (14 digits) you can find this number under the camera.
Once you're in the Web Main Menu, click on Site Map. There you can choose what you want to see in the screen of Monitor1 (My menus are in Spanish, maybe your menu says something like "screens" but I'm sure you'll find it)
If you choose Monitor/Screen 1 as Svideo, and select it as output for Local, Remote and Content you should see the Main Menu after the VSX7000 Reboots.
I hope it would be useful for you, if you have any problem with this let me know... This VSX7000 is working fine now, so yours should work!
Sep 19, 2007 | Polycom VSX 7000 Video Conference
Polycom VSX 7000 Video Conference Logo
55 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
