Question about HP Pavilion M70 17" CRT Monitor
My HP Pavillion M70 monitor is saying "video cable connected?" when I try to use the monitor. I am trying to output my laptop to the monitor because my laptop screen is wearing out, but I cannot get it to work correctly. I set the monitor output options to dual output, but the monitor still says the same thing.
  • 75 Answers
Go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located at the lower left of the keyboard, normally between the CTRL and the ALT key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5, Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations with the age of the laptop and not all manufacturers have standardized on a key combo across the whole range, but you can usually figure it out from the little graphics on the function keys that line the top of the keyboard.
Posted on Aug 25, 2010
HP Pavillion laptop Model # ze4220. Does not display anything on the screen . Tried pushing fn + f5 3 times, like the manual suggested to no avail. Help?it
Could be screen is bad. Try connecting a monitor to the monitor output if one. If monitor works then your screen is definitely fubar. If it also does not work then the video circuits of laptop are gone.
If laptop is the messed up you are screwed since the video circuits are all part of the mo bo and the entire board would have to be repaired. HP will soak you for the board and labor. Cheaper to replace laptop.
Sep 28, 2016 | HP Computers & Internet
No screen display on toshiba M70 laptop
Try plugging in to the external monitor again and toggling the video output using FN+F5 a few times. If it eventually displays on the external monitor, but nothing ever displays on laptop screen after trying this a few times, the issue could be with the laptop screen, in which case you'd want to have it checked by a repair shop:
http://forums.computers.toshiba-europe.com/forums/thread.jspa?threadID=62553
Apr 15, 2012 | Toshiba Computers & Internet
HP pavillion a6300f pc when powered on, the fans come on and can feel the hard drive spinning, however there is no video output; I took the pavillion to another pc monitor and same result, no video output....
If it shows the bios on your screen.... Try to go the bios setting and make check the "default operation" and save upon exit.
Check the Motherboard, if there are swollen/bulging capacitor on the board, replace it.
If there are no bios whatsoever, sad to say, problem will be the board already......usually the bios chip that breaks down.
Try to use another power supply, sometimes the power supply is the culprit of the boards problem.
Hope that helps you out!
Aug 09, 2011 | HP GX613AA Pavilion A6300F Desktop PC
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
I have a 25" JVC
Try pressing Fn + F5 on your laptop to output the TV. Alternatively, on the display driver of your laptop there is a properties to use as a dual output.
Mar 11, 2011 | Televison & Video
Acer lcd al1706 a monitor hooked to hp pavillion laptop and previously it worked great but i disconnected it to move and now reconnect and all plugs are fine and connected but monitor says "no...
You should try this monitor and the video cable with another PC to see if it works OK, or try this laptop with another monitor to see which one is not working, I have a feeling something has changed in the laptop setup.
Please post back what you find.
Jan 15, 2011 | Acer AL1706AB LCD Monitor
My monitor says "no input signal" every time I put it on. I have checked all the wires and connections and they seem fine. Any suggestions?
Starting from the monitor and going to the video connection to your computer, make sure everything is connected and undamaged. If your video card has more than one output, try switching the cable to the other output. If neither is working, and the monitor works fine from a different computer, then its the video card, otherwise its the monitor. But again, before dropping any money on a new monitor, try a different cable, and try switching the cable to the second output if there is one. A video card is definitely cheaper than a monitor.
Aug 22, 2010 | HP Computers & Internet
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
M70 crt
just check the power cable from the monitor is connected properly or not try reconnecting it...
may be there is some loose contact in power cable............
check the cable which connects the cpu from the monitor is connected properly check whether is there any loose contact try reconnecting it...........
if problem persists then there is a problem with operating system try reinstalling it....
Feb 10, 2008 | HP Pavilion M70 17" CRT Monitor
HP Pavilion M70 17" CRT Monitor Logo
165 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
