Question about Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat
Hot water does not always come on......getting berror 24
  • 68 Answers
There is a malfunction of operational switch
you will have to press the max button on PCB to reset
and Press min button on PCB to reset
if that does not work you will have to get the PCB replace
Posted on Aug 25, 2010
I have main combi 24 if you run water slow it is hot but if you turn it up it is luke warm water
see pic;
Notice the red in the 1st picture? That is all hot water. When you have a broken dip tube the cold water is 3/4 of the water heater.
So like in your case, if you run water slower you may get hotter water longer, but if you run at faster rate, hot water short time and then cold.
Check & if needed replace the dip tube. Easy fix
Feb 25, 2015 | Water Water Heaters
Why am I not getting hot water flowLike I use to
Your hot water tank may be clogged with sediment, especially if it has not been maintained correctly.
Sep 02, 2014 | Water Heaters
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
Doesn't always come on with hot water is turned on
Water heaters draw water into the bottom, and as the hot water heats, it rises and hot water exits from the top.
You might want to check each fixture, does the hot pipe (tubing)feel warm when you run it for a moment. Can you get warm water from some of the fixtures, but not others?
I'm bet there is a leak at the top of the intake which is filling from the top down, instead of bottom up.
Dec 27, 2012 | Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
My shower is not hot enough unless I turn the cold water on in the tub at the same time
You might have a plumbing problem.
1) Faulty check valve
2) Crossover at single handle faucet
Read: http://waterheatertimer.org/pdf/No-Error-Code.pdf
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 31, 2011 | Stiebel Eltron TEMPRA 24 Tankless Water...
Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat Logo
81 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
