Question about Elgato Systems Elgato EyeTV Hybrid - DVB-T receiver / analog TV tuner / video input adapter - Hi-Speed USB (EYETVHYBRID)
We are coming from Malaysia, Sabah (East coast of Malaysia). We are now using 55cm KU band satellite Dish for receiving Astro Channels/package (Pay channel). So, I decide to use existing satellite dish and plug with DVB-S receiver so receive the channels that provided by ABS 5. Is that possible?
Will all models work in us and aus
Foxtel in Aust says they use dishes 80cm and above, even to 120cm in some areas. So your 60cm dish will likely struggle to give a reliable signal.
I have a Foxtel contact, so post an email address if you would like that sent to you.
Dec 02, 2013 | Intellian S6HD US KU-KA Dual Band HD...
Can I use a dish 500 dish with a VIP722K receiver Ilive In eastern Pa.
If you have a clear view of the south western sky, the receiver will receive most channels (after running a check switch test, menu, 6-1-1). You will not receive most HD (which comes on Eastern Arc satelllites not on that antenna, or on satellite 129, not on that antenna) and depending on your DMA you may not get locals, but most cable channels will be available, at least in Standard Definition.
Aug 08, 2013 | DISH Network Televison & Video
My VIP722 DVr keeps showing that I have a complete loss of signal. This goes for awhile and can receive no HD channels. By going to DVR I can then go to guide and get SD channels only. But then after...
Hello this is Nick Franta with DISH Network.
What error message are you receiving on your screen? There should be a 3 digit number in the top right of the message. Has there been any bad weather in the area which may have affected the signal?
If you haven't been advised to already, I would suggest doing a hard reset of the receiver by unplugging it from the outlet for 10 seconds. When you plug it back in the receiver will reboot itself for you. If you are still getting errors hit the menu button then 6-system setup, 1-installation, 1-point dish, and then hit check switch and then test. All your satellites should show green. If not we would need to send a tech out to address the issue.
Hope this helps!
Jan 12, 2011 | DISH Network 311 DTV Receiver
I have an old and I do mean old satellite dish and reciver and I.m trying to get it to work and Im having a hard time doing it on the reciver it says that it is a president and it is also a ps600xl do...
Here's the user manual for it
http://www.uniden.com/pdf/PS600XLom.pdf
But i don't understand why do you want to use it - it's a C/Ku band analogue receiver, there aren't many satellites emitting this way left. Actually all professional ones have been retired so you can't use it to view tv channels.
Oct 08, 2010 | Computers & Internet
Trying to find out what my tvs settings should be on to hook up m
Have you tried channel 3 or the video input channels.
The Tv only needs the one channel that the signal from the box is sent on.
All the viewing channels will be changed through the satellite box.
May 11, 2009 | LG Televison & Video
No local channels
your locals may be broadcasted on a a different satellite (directv uses 7 different ones). when u travel, your dish on your rv might be capable of receiving the satellite that broadcasts normal programming. the dish on your home may look a little different and picks up more than one of the satellite signals. also these satellites are in different locations
Oct 23, 2008 | Philips DIRECTV H20 DTV Receiver
Cannot get new dish to work
You need to call Dish and have them authorize the new receiver. They may send you a new smart card depending on the receiver. Also, if there is an outstanding balance on the one you were given, they likely won't authorize it.
Jun 07, 2008 | RCA DISH Network(r) 311 Satellite System
Fortecstar lifetime ultra
It will pick up the free to air channels that are being boradcasted in C band and Ku band to that area.
You can check www.lyngsat.com for more info on what satellites you can get in your area.
May 09, 2008 | Fortec Star Lifetime ULTRA
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
Elgato Systems Elgato EyeTV Hybrid - DVB-T receiver / analog TV tuner / video input adapter - Hi-Speed USB (EYETVHYBRID) Logo
77 people viewed this question
Top Elgato Systems Televison & Video Experts
Are you an Elgato Systems Televison and Video Expert? Answer questions, earn points and help others
