Question about Dell Dimension 4500 PC Desktop
My Dimension 4500 won't start. I see fan in back working and it beeps a few times. Diagnostic lights are all yellow except the C which is green. Only one green. Please help me.. Thanks, Joe
  • 1,472 Answers
Jose_Jose_hi
Unfortantly the diag lights show that the issue is with the CPU. If you have moved your computer resently you may try to reseat the CPU in the socket. However most likely you will need to replace it.
Let me know if you have any more questions
Issken
http://www.fixya.com/users/issken
Posted on Aug 25, 2010
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
ABC diagnostic lights are green and D is yellow. Ram only works if slot 1 is used. If slot 1 and 3 are used Bios appears on the monitor with a flashing cursor. Dell dimension 8400
A,B,C green and D yellow is indicative of a component failure...in that the system cannot read a device it feels necessary to boot the machine such as a hard drive, floppy or cd/dvd drive. Power down the system, remove the power cord from the back, push the power button in for 10 seconds to bleed off the power. Remove and reseat all cables connecting the system devices. Remove all ram except for one stick and reboot. If you get boot, then try replacing the ram one stick at a time. If you still cannot boot though, try removing the cables from the devices and then plug in one a time until you get the machine to boot. If there is still a problem, the hard drive or its controller maybe the culprit.
Jun 14, 2010 | Dell Dimension 8400 PC Desktop
Dell Dimension 8100. No start!
Look on the back of the case where the devices plug into it. There will be a set of 4 led lights. starting from the top down oe left to right depending on how they are situated, look at the lights and this is a doagostic of what is happening during the boot sequence. These are green and yellow lights and their order and color are the signifigance of what is wrong, if you have your manual, the meaning of the colors is in there under troubleshooting. I'll see if I can find it......check this out
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm
Sep 29, 2009 | Dell Dimension 8100 PC Desktop
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
Dell dimension 8100 diagnostic lights
please refer to the below link...being dell support technician myself this link would give you the best possible help
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm#diagnostic_codes
Oct 18, 2008 | Dell Dimension 3000® Pentium® 4...
Dimension 4500S
hi!,
I hav a solution 4 u . Ur LCD monitor's wires of ur Laptop Has gone loose , U can just give ur lappy 4 a servicing.
byeee........
Mar 08, 2008 | Computers & Internet
Dell Dimension 4500 PC Desktop Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
