Question about Frigidaire 26.0 cu. ft. Side-By-Side Refrigerator
Frigidaire frs26h5asb5 ice maker makes big clumps which overflow
  • 42 Answers
SOURCE: ice maker makes ice, but also drips water
cbscarter,
This may sound strange but you will find that the mold coating is peeling off of the aluminum mold. This causes the water to wick (climb) the loose coating and up over the top, leaking out making an ice clump on the ice maker and clumps ice in the container together. It would be easy enough for the average person to replace the ice make. Due to its age that would be smarter to replace than to repair the old one. It is a Whirlpool part #4317943 and comes with some instructions.
If this helped please rate me good, supertechks
Posted on Nov 25, 2008
SOURCE: My ice maker won't make ice.I have a Frigidaire
I had the same problem with my ice maker.
I took it apart and cleaned the three switches inside the icemaker
The switches are not a high enough amp rating so they burn the contacts. Keep in mine cleaning is temp fix.
I did mine about 4 months ago and still working.
I have new switches now that I will be installing as soon as it quits again. About $9.00 for new switches and about $130.00 for a new Icemaker!
I hope this helps.
Posted on Feb 24, 2009
  • 415 Answers
SOURCE: Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Posted on Aug 19, 2009
tzweeb
  • 318 Answers
SOURCE: ice maker over fills the ice cube tray over
most likely the i/m needs replaced. what happens is the coating inside the mold is peeling off and causing the cubes to stick and then melt the cubes instead of releasing them. when this happens it will cause the unit to overfill the next cycle and leak into the bucket.
Posted on Jan 07, 2010
SOURCE: ice cubes are turning into a clump of ice
I found a high density foam and a plastic retainer under the freezer drawer, inspected ice maker and found a wire with a rectangular senser hanging down. Removed freezer drawer and door to gain access to icemaker. Reinstalled foam piece and plastic retainer to lower front of icemaker (there are recess and a small retainiing tab) Reassembled freezer door and drawer, system working normally
Posted on Feb 25, 2010
Frigidaire PLHS67EESB0 ice maker stopped not making ice and the ice ejector keeps turning and the machine keeps filing with water and overflows
If the ice ejector turns constantly, and water flows with each turn, you have a bad limit switch inside ice maker. This switch stops the motor inside, and thus the ejector, and allows for a freeze cycle. There are other possible problems but i suggest just getting a new ice maker. Not that hard to change out if you have any mechanical skills.
Oct 12, 2013 | Frigidaire Refrigerators
Ice maker makes ice however there is a big clump of ice stuck to the bottom of the bin. It keeps happening each time I remove the clump. I have replaced the 2 valves in the back of the refrig/freeze
Sounds as if the tray is running over. Are the cubes oversized? If you remove the cover (front, usually) from the icemaker you'll probably find a fill adjustment -- a screw with + and - markings. Rotate the screw 1/2 turn in the - direction and see if you notice a reduction in cube size. If it's running over, you may need to make more than one 1/2 turn adjustment.
Jan 10, 2018 | Maytag MSD2758GEB Side by Side...
Ice from ice maker sticking together. Is the temp in the freezer to high or to warm causing this?? The ice is just one big clump of ice cubes all stuck together!!
to warm or maybe staying in deforest to long if you don't have a good amount food in the freezer it will warm up in deforest and make ice to lump
Sep 29, 2010 | Frigidaire Refrigerators
My frigidaire side by side freezer freezes up and the filter in the refrigerator leaks water. It makes ice fine but will not freeze ice cream. theres a big clump of ice in the back which is under a cover...
the leaking water is the problem. it needs to be fixed, but till then defrost again, use a fan it speeds the process, SHUT OF WTER to ice maker. restart fridge it will work normally. now find parts needed to fix the ice maker water feed.
the leaking water overwhelms the defroster. and causes a coil freeze up, this impedes cooling and air circulation over the evaporator coils
Jun 15, 2017 | Frigidaire FRS23KF7AB Side by Side...
My ice maker won't make ice.I have a Frigidaire FRS26H5ASB5. Can you tell me what I can do?
I hope this helps.
Feb 23, 2009 | Frigidaire GLRS264ZA Side by Side...
To much water injecting in ice maker
you can not adjust it enough if it is overflowing I would try a new water valve first cause it is cheapest but if it dont fix it then get a knew icemaker
Dec 30, 2008 | GE GSS20IEP Side by Side Refrigerator
Ice maker /themostat
ARE YOU TALKING ABOUT THE THERMOSTAT ON THE ICE MAKER IF SO HAVE A TECH TO SERVICE AND REPAIR IT.GOODLUCK.MOHAMED
Aug 03, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Dec 08, 2007 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire 26.0 cu. ft. Side-By-Side Refrigerator Logo
104 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
