My hp 7300 gives me a paper jam error at turn on and there is no paper jam. It will not go past that point even when I press ok.
  • 1,218 Answers
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer’s recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert technician to mend it. get more information and help from here.
Posted on Aug 25, 2010
I have a 7300/7400 HP Office Jet printer....keeps giving false alarms on paper jam. I have done everything the book says. The print cartridges do not return to the right. I love this printer and
there are a few sensors in the paper circuit. if those sensors have some small pieces of paper you will continue to get this error. If you have serious mechanical skills you can try to disassemble the printer and clean every sensor. if not you should go to a specialized service center.
Jan 17, 2012 | HP OfficeJet 7310 All-In-One InkJet...
I have a HP Photosmart C6380 printer locks up & gives error
it is likely that you have had a jam which damaged the sensor when you removed it (itr if you print lables gunked it up). If it is likely to be gunked up you could strip and clean but to be honest it is probably not worth the time. If this has iccurred following a jam - unless you have another identical machine for spares bin it and get a new one as the parts are difficult to come by and labour will be steep unless you can do it yourself of course
Jul 12, 2010 | HP Photosmart C6380 All-In-One InkJet...
Turned it on and it says paper jam. There is no
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 22, 2009 | HP PhotoSmart C4280 Laser Printer
Open door cariadge jam
this error generally comes in when there is actually a paper jam or it gives a false paper jam.. so first of all make sure that these should not be any paper stuck inside the printer.. clean all the paper rollers with a little moist lint free cloth.. then plug the printer directly to the wall jack for the power supply if not connected..
if it doesnt resolve the issue.. we may have to perform a reset as well ..
Oct 22, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Sep 04, 2017 | Office Equipment & Supplies
HP 7210 OfficeJet All-in-One errors
My Hp came with a setup CD that has very specific (required) drivers. Truthfully, if you machine is using the wrong drivers for the selected printer, it will interpret the bi-directional communication with the printer wrong - as evidenced by the false "Paper Jam" message.
Here's a path to HP's drivers for the 72000 series printer and Mac OS.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=219&lc=en&cc=us&lang=en&dlc=en&product=391153
Dec 30, 2007 | HP Officejet 7210 All-In-One InkJet...
Clicking Noise
Go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00587637&lc=en&cc=us&dlc=en&product=439488&rule=44236&lang=en and I think you'll find what you need to solve the problem. often this type of error is caused by trying to clear a paper jam by pulling it out the wrong way, one or two of the gears slip and everything gets out of sync. If you can't solve your problem with the HP troubleshooter, please ask again and I can try and talk you through the resetting process. Hope this helps:)
Feb 27, 2007 | HP Photosmart 3210 Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
50 people viewed this question
jasbo
jasbo
