Question about Daewoo DSJ-6000LN 60" Rear Projection Television
Daewoo dsj-6000LN TV will not turn on. Pushing the power button caused the TV initially power on - then the timer light blinks and the TV will not turn on at all
WHERE CAN I GET A REPLACEMENT LAMP FOR MY DSJ-6000LN TV
Posted on Sep 12, 2011
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Connecting new tv & we can't view picture onle hear sound
What must be done is to double check your inputs and confirm if there are issues in the inputs be it the RF or Video inputs. If there is no picture on any of these then the best thing to be done is to lodge your complaint as the TV is new and must get a free service replacement for any spare. Hence I request that no work be done if the matter is confirmed.
Also test your input signals.
Oct 17, 2011 | Daewoo DSJ-6000LN 60" Rear Projection...
NO PICTURE ONLY SOUND
just ask the daewoo service center to repair your tv
Jun 19, 2010 | Daewoo DSJ-4710CRA 47" Rear Projection...
Tv power on and sutdown after a series of bips the green light change to red and stay red
Tv power on and sutdown after a series of bips Problem with the Daewoo DSJ-6000LN 60 in. Rear Projection Television tv power on and sutdown after a series of bips the green light change to red and stay red
Jun 15, 2010 | Daewoo DSJ-6000LN 60" Rear Projection...
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Standby light comes on but TV won't when turned on
I am having the same problem. Have you had yours repaired yet?
Dec 01, 2008 | Daewoo DSJ-5510CRA 55" Rear Projection...
Daewoo projection tv...looking like 3-D
if the TV you are talking about is the DAEWOO DSJ-5510CRA.. u having a
convergence problem.. i hope this can help u in some way.
Oct 02, 2008 | Daewoo DSJ-5510CRA 55" Rear Projection...
Black screen
you need to pull the back of the tv and check the fuse. some of the tvs of your kind have a fuse that could pop.let me know how or if this works at www.gillardk@yahoo.com
Dec 27, 2006 | Daewoo DSJ-4710CRA 47" Rear Projection...
Daewoo DSJ-6000LN 60" Rear Projection Television Logo
146 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
