Question about Dell 1703FPs 17" TFT LCD Flat Panel Monitor
The screen afetr minimum use
The screen after minimum use goes blank. After turning it off then on stays on for a few seconds then goes balnk again. Any suggestion? It is an A-open monitor Model number F75PS made in 2003
    Novelist:
  • 77 Answers
Hi John,
Its a possible loos contact in the VGA port that connects your monitor to the PC. Switch off everything, check for all possible loose connections, inside & outside the PC's cabinet, rectify if any found and restart.
If the problem still persists then there's something wrong with the Power Options Settings that you may access thru control panel. I recommend that under the First Tag i.e. Power Schemes select "Never" in all the dialogue boxes for turning off Monitor, Hard Drives & System Standby and under the 3rd Tag i.e. Hibernate, make sure to uncheck the box next to Enable Hibernation.
That's about it. I feel this should solve your problem.
Posted on May 05, 2008
ACER EXTENSA 5420 BIOS Alteration Problem
restar the computer HOLD the key CTRL +F2 and ready.
God bless you
May 22, 2013 | Computers & Internet
Problem with kodak z650 camera wont stay on
Hello Francine, Sounds like internal fault, need to have service check,may be too costly to repair.
Best Regards, Russell
Jan 21, 2013 | Kodak EasyShare Z650 Digital Camera
My monitor goes blank after a few seconds of turning my computer on. I turn off the monitor & turn it back on again and it only stays on for a few seconds thanks
It basically goes to Power Save Mode. Check for the same error in System Setup screen, if the Monitor goes off in System Setup then you better need a replacement. Else you would need to reseat the Video Card(If any) and the Memory Modules. Please keep posting for any further issues / improvements.
Dec 30, 2009 | Dell Computers & Internet
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Turn on no picture but power lite on
if you spilt something on it that would be a reason
Jul 20, 2009 | Nintendo DS Lite Console
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor goes blank after first few seconds of turning it on...
There's an internal electronic part/s of your monitor that are cold soldered / defective. I suggest to bring the unit to an authorized service to properly diagnosed & fix the problem. best regards
May 25, 2009 | Proview PT 15.1" LCD Monitor
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Dell 1703FPs 17" TFT LCD Flat Panel Monitor Logo
128 people viewed this question
Alun Cox
