Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Windows 7 says Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) Canon Powershot SD750
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Nov 03, 2012
SOURCE: Canon IXUS 70 Downloading to computer.
I've Canon IXUS 70.
My camera is full with images.
I can't download images to my computer.
Pls help me that:
How can i download the images from my camera into my computer.
Thanks in advance.
srinu
Posted on Feb 21, 2008
  • 108 Answers
SOURCE: USB trouble with SD1100is
Code 19 Your registry may be bad. (Code 19) To check your registry, click Check Registry. If the registry is bad, Windows will restart your system and go back to a previous registry that is good. Solution button: Check Registry This code means that the registry returned an unknown result. To resolve this issue, follow the recommended solution, which will run Scanreg.exe. If this does not resolve the issue, type "scanreg /restore" (without quotation marks) from a command prompt. Finally, remove the device from Device Manager, and then redetect it using the Add New Hardware tool in Control Panel. Hope this help's ;)
Posted on May 25, 2009
  • 11967 Answers
SOURCE: I plug my camera into the computer and nothing
Try using a separate card reader instead of the camera. Works every time.
Posted on Apr 23, 2010
  • 11967 Answers
SOURCE: My PC is not recognizing my camera, so i cannot
Windows updates has changed the registry and now your camera is no longer recognized. No problem....just get a card reader and use it instead of your camera for downloads.
Posted on Oct 13, 2010
muntejaya
  • 10421 Answers
SOURCE: Having problems downloading pictures from the
Please get the driver here : www.driverskit.com/Camera/Canon.html
www.driverslab.com/drivers/Camera/Canon/16/22.html
www.usa.canon.com/cusa/consumer
Regards, Jay__GT
Posted on Feb 18, 2011
Device code 19
go to iobit.com download the free driver booster upgrade for free software and run it to get the correct drivers for your machine
make sure all devices are in place when you run the software from iobit
Aug 17, 2013 | Computers & Internet
Not working my cd drive.
If you are running Windows 7 you can use C Cleaner or Windows 7 Manager to clean up your registry if you don't have them you can download Regcure or Registry First Aid to clean up the reg error then you can restart your computer and see if windows can reinstall your hardware.
Oct 20, 2012 | OEM Systems Acer Aspire 5742g Dvr-td11rs...
My lenovo 3000c series also have this problem, code:19. please advise.... thank you
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged or corrupted.
Probably data in the registry for the device and its driver have been damaged/corrupted
Try these options,
•Click Uninstall, and then click Scan for hardware changes to load a usable driver.
or
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back or restore to the most recent successful registry configuration.
Hope it helps.
Aug 12, 2010 | Computers & Internet
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you should uninstall and then reinstall the hardware device. (Code 19)
Try these options:
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
Hope it helps.
Jul 10, 2010 | Microsoft Windows Vista Ultimate Edition
Code 19 DVD DX not working
  • Open up your Device Manager where you'll see your DVD DX Hardware Device that no longer works correctly. Click it, and then click uninstall. Once uninstalled you can reboot, or click 'scan for new hardware'. Either way Windows will find your Device again and reinstall the driver and probably fix the registry entries.
  • If that does not work, reboot your computer holding down F8 and select 'Load Last Known Good Configuration' before booting into Windows again. It'll restore your settings back when it didn't detect any problems.
Apr 21, 2010 | Computers & Internet
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP
hope this helps
please leave feedback
thanks
Robb
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
Nov 22, 2009 | Acer Aspire 5315 Notebook
Error 19
Dear Sir,
Error 19 indicates that the Player and the RealServer were unable to communicate properly. Please check connectivity.
Cheers
Sep 19, 2009 | Microsoft Windows XP Home Edition
UNABLE TO DETECT CD/DVD ROM
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Your registry might be corrupted (code 19)."
You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Sep 28, 2008 | Compaq Presario Notebook
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
