Question about Mitsubishi WS-65819 TV
Flashing green light won't stop - Mitsubishi WS-65819 TV
  • Agus Yustiara
    Agus Yustiara Aug 25, 2010
    but how with the TV, still power on and get the picture?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 25, 2010
Won't start up little green light flashing on back
the green light flashing on the backside is your internetconnection.
about the computer wan't start i should check the PSU do the fan movs any light on the motherboard.if not is the electric cord firmly and tight in place.if the fans runs and lights on the motherboard.you got no picture proberly brooken videocard.
Apr 11, 2013 | Computers & Internet
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
The green light on my prince lionheart warmer won't stop blinking
I realize the original question is 2 1/2 years old but for future answer searchers... the flashing light means your power cord is no longer working.
Jan 18, 2013 | Prince Lionheart Premium Wipe Warmer
Dolce gusto kp2100 won't stay on
in the machine there is small circuit board that control the machine so they programmed that circuit to preheat the heating element for about 30s if this failed the red light flashes two tims then stops so you have to change the circuit board
Oct 07, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
My tv the light is flashing red green an won't
replace the power supply board. You can get replacement power supplies from www.tvcircuitboards.com
Mar 07, 2012 | LG Televison & Video
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Wireless mikes won,t connect to the base,just keeps flashing green light
press the connect buttons both @ the same time,& hold them until they both stop flashing.
or check battery in mic.
Mar 01, 2011 | Magic Star Karaoke Microphone
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-65819 TV Logo
105 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
