Question about D-Link DMC 810SC (DMC-810SC) Media Converter
When i coonect the 1000base-t port of media convertor DMC-810SC to a switch with 100base-t port the the link will loose, and it should be a switch with 1000base-t to work properly. How can solve this problem?
2 Suggested Answers
SOURCE: Hello dear I am using two
ufs setp error whts problem
Posted on Jul 09, 2011
Power light gs105
http://kbserver.netgear.com/pdf/fvs114_ref_manual_29Apr05.pdf
Here is the Troubleshooting Manual
Apr 11, 2013 | NETGEAR ProSafe GS105 - Switch - 5 ports -...
How to upgrade from 100Base T NICS and 100Base T switch on CAT5 Cable to 1000Base T
You can't. 1000 requires 1GB NICs, 1GB switches and at least CAT5e or CAT6.
Jan 21, 2013 | Computers & Internet
Nortel 425 switch problem all leds are contentsly blinking
there might be looping issue, please unplug all the cables from the switch and then put one by one cable in each switch port and make sure that both ends or the cable should not plug to the swithc... also check in your network there wont be virus infected pc or device..
Dec 14, 2011 | Nortel Networks 425-48T Managed Ethernet...
All lights on all connected ports on a netgear gs105 switch rapidly flashing constantly; data traffic seems slow or drops. Occurs regardless of how many devices connected or which ones.
1. A switch is a dumb device it just transfers data via the ports
2. if you are having slow or dropped data this possibly is due to bandwidth issue.
3. contact your internet service provider to check your speed and you line condition.
4. You didn't say if you were using a router, but if so this could what is call "collision"
5. some switch do this due to speed of the data throughput\.
Jun 23, 2011 | NETGEAR ProSafe GS105 - Switch - 5 ports -...
How can I activate PoE port on avaya2526T switch?
Try this: http://www.retrevo.com/support/Nortel-2526T-PWR-Switches-manual/id/8084dj990/t/2/
Jun 18, 2011 | Nortel 2526T-PWR Ethernet Routing Switch...
Switch not connect hyper terminal
If you are connecting to the switch using the console port using a console cable. Make sure your settings for hyper terminal are on COM1 and the baud rate is 9600.
If you are trying to telnet, you will need to assign an IP address to the VLAN in order to telnet into the switch and configure a password or it will not let you in.
Mar 04, 2011 | Nortel 2526T-PWR Ethernet Routing Switch...
Confi stack on nortel switch 2526
Hi friend i want help can you give me the reply. i have 4 nortel 2550T-24 port switch but i don't know how to active stack config.
Sep 27, 2010 | Nortel 2526T-PWR Ethernet Routing Switch...
Lost Power Adapter for Unicom Mini-switch/8 8 port
method 1: buy a power adapter that has a switch controlled output voltage - they usually have 3V - 4.5V - 6V - 7.5V - 9V and 12V selectable output. Start with 6V and if its not working unplug, select 9 and try again etc. etc.
method 2: open the case and locate an electrolytic capacitor right near the power plug - the biggest one. Note the voltage (for example it may say: 1000uF/15V) and have in mind that your device MUST work at a LOWER level that this.
you can combine the two methods to be safe...
Oct 02, 2009 | Port Incorporated 8-port 100Base-TX Mini...
D-Link DMC 810SC (DMC-810SC) Media Converter Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
