Question about Maytag Neptune MAH5500B Front Load Washer
My mytag neptune front load washer, does not work, indicates more then one button pressed, how to re.set?
  • proyectosara Aug 25, 2010
    Indicates to press start/off button or select down, wich is not responding.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To reset the washer leave the unit unplugged for 10-15 minutes, if still it won’t work then you’ll have to replace the control panel as that seems to be bad. However, before replacing the control you can take it out and try to blow air with the help of hair dryer so that if there is any moisture it blows it off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 26, 2010
  • 1,998 Answers
If you have two or more buttons pushed in at the same time then you might be seeing an f7 code appearing u can try to get it unstuck there is actually a slim chance that one would unstic but then when it did you wouldnt be able to use that button again best thing to do is buy and install a new touchpad taking apart the touch pad i have seen techs do but it really isnt worth the amount of time that it takes to repair would end up costing you more then buying a new touch pad please remember to rank how this opinion has help your appliance situation and if i can help you with any other questions please message me back thank you again have a great day
rickead1
Posted on Aug 25, 2010
Maytage neptune front loading washingmachine, display is flashing "nd" can you tell me what that means? I cannot find my owner's manual
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.##@@@@
Feb 15, 2010 | Maytag Neptune MAH6500A Front Load Washer
The lights go on, but washer will not start.
door not closed try open door and then closing again
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune front load washer showing code LO. Door
You can try either prying the door open and then replacig the door switch which is probably what caused the problem in the first place. Or try unplugging the machine for several hours, press and hold power button for a few seconds, wait half hour more, plug back in to see if it resets itself.
Nov 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load washer wont start when button pressed
This is joyce
first lets start simple unplug the machine and leave unpluged for 1 min. replug back, see if this solves the problem.
thanks,
joyce
Feb 06, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
Aug 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
29 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
