Question about Microsoft Windows XP Home Edition
Unable to load dos prompt
I am using xp sp 2. i placed shortcut of command prompt key on desktop. recently, when i double click on shortcut of commdand prompt, dos prompt is not loading. i checked it in thru strat, all programs, accessories, command prompt with no sucess. futher i found regedit also not working. please help me in resolving this.
    Problem Solver:
  • 6 Answers
This is probably caused by a virus. Try scanning it with your antivirus program, after you make sure your virus definitions are up-to-date. You can also run Trend Micro's Housecall if you have an internet connection. It is free. Just do a search for it, run it, and see if it finds anything.
Hijackthis is another good resource to try. Find a copy on the internet (it is free) then post your log that it makes on a website for others to help you find the bad files that are causing the problem. ASP free forums has this type of help.
FYI- another way to start the command prompt is to go to Start > Run > type cmd >hit enter. You can try to see if it starts this way, but I bet it is a virus or other malware.
Posted on May 05, 2008
How do I do a factory reset from safe mode with command prompt? windows xp
Restoring Windows XP operating system can be performed in DOS mode if XP's system restore tool cannot be accessed because of booting issues or when the XP recovery CDs are unavailable. There are two steps to this procedure: first, the XP system restore tool must be accessed using the DOS menu and second, the actual XP system restore is performed.
Start the computer and press the F8 key when the manufacturer's logo appears but before the Windows XP logo appears. Scroll through the menu options using the down arrow key. Select "Safe mode with a Command prompt" and hit the Enter key. Type in the administrator ID and password. Hit "Enter." Type in this code in the command prompt box to access the XP system restore tool: %systemroot%\system32\restore\rstrui.exe. Hit "Enter." The XP system restore tool will open. b> How to Restore Windows XP b> Click "Restore my Computer to an Earlier Time" when the XP system restore tool starts. Click "Next." Choose a restore point before your operating system began to malfunction. Click "Next" and "OK." Click "Next" to begin the XP restoration process. Do not turn off the computer or attempt to stop the system restore tool, as this may damage the hard drive. The system restore tool will automatically restart the computer when it has finished restoring the operating system. Hope this helps.
Dec 12, 2012 | Computers & Internet
Tip
HOW TO CHANGE IP ADDRESS
To change your network IP address in Windows XP, Vista, or 7:
1. Press the Windows Key and R
2. Type command and press Enter. This loads your DOS prompt
3. Type ipconfig /release then press Enter. This disables your internet connection
4. Go to your desktop, and right-click on something called Network Place or My Network Places (If you're using Windows Vista or 7, look for the Network and Sharing Center through Control Panel)
5. Click Properties. You should now see something called Local Area Connection or something similar
6. Right-click on your connection (titled Local Area Connection if you're using an ethernet cable or Wireless Network Connection if you're on WiFi) and click Properties
7. Under the General tab, double-click on the Internet Protocol (TCP/IP)
8. A new window appears. On its own General tab, click the box beside Use the following IP address
9. Type in ones until you fill the box up (it should read 111.111.111.111)
10. Press Tab. You'll notice the Subnet Mask section automatically fill sup with numbers
11. Click OK
12. Click OK to bring you back to the "Local Area Connection" screen
13. Right-click Local Area Connection and Click on Properties again
14. Again, under the General tab, double-click on the Internet Protocol (TCP/IP)
15. Select Obtain an IP address automatically
16. Click OK
17. Click OK
18. Go back to your DOS prompt, type "ipconfig /renew" and press Enter. This restores your internet connection.
By now, the network should've assigned a new IP address to your computer automatically.
on Jul 22, 2010 | Computers & Internet
Tip
OPENING COMMAND PROMPT WHERE ITS BANNED
Like i always say notepad is a very handy thing. You can do a number of things with it.
Do u know you can open a command prompt just by the help of a notepad.
Type
command.com
and save it as dos.bat
now double clicking dos.bat will get you the prompt
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Need to change video display in Autocad running in DOS
Hit the "Alt" and "Enter" keys at the same time while in the full screen window. This will change the full screen to a window.
Right click the blue bar at the top of the window. Choose "Properties." Click on the "Options" tab. Make sure the setting is on "Window" rather than "Full Screen."
Click "OK." When you are prompted with save options, choose "Save Properties for Future Windows with Same Title."
Change the properties for the general command prompt. Click the "Start" button. Click "Programs" and "Accessories." Right click the "Command Prompt" icon.
Navigate to "Properties." Choose the "Options" tab. Check the button next to "Window" instead of "Full Screen." Click "Apply," then "OK."
Use the mouse to right click on a DOS program's shortcut. Choose "Properties." Select "Options." Under "Display Options," select "Window." Click "Apply" and "OK."
Open the command prompt or your DOS shortcut. Right click on the blue bar. Click "Properties" and go to the "Layout" tab. Under "Window Size," use the arrows to increase the height and width of the window. Click "OK," click "Modify Shortcut That Started This Window" and click "OK."
Custom Car Parts
Jun 06, 2012 | Autodesk Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Copying to c:\ in vista using batch files..
You need to left click the batch file and "Run as Administrator".
Nov 01, 2009 | Microsoft Windows Vista Ultimate Edition
I like to use dos on full screen mode
create shortcut on desktop by right clicking on desktop ->new-> shortcut->type command->next
after shortcut appears on desktop
right click on the msdos prompt icon -> Properties ->Screen tab -> choose usage as full screen - > apply and ok...
try opening dos... u'll find dos in full screen...
May 26, 2009 | Dell Inspiron 2200 Notebook
Firewall settings
This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service.
Resolution
Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
After restarting Windows, run the following from Command Prompt (cmd.exe)
NETSH FIREWALL RESET
Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
Restart Windows, and then run this command (from Command Prompt):
Attempt to start Firewall applet. Start the Windows Firewall service if prompted.
Apr 21, 2008 | Microsoft Windows XP Professional With...
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
177 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
