Question about GE Refrigerators
I have a GE Profile Arctica Modle # PSS27NGMC BB and my problem is that it keeps beeping by the control on the front of the freezer door. We use the water and ice make buttons and that's it. We can't understand why it started beeping and how to get it to stop. Please hepl.
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
Speed boy
  • 76 Answers
SOURCE: GE Profile Arctica Side by Side with ice maker and water in door
Plz provide me with the full name and model of your appliance for there is a lot of diferent makes and sizes,plz reply asap so we can sort this problem out for you.
Thanks...
Wouter.
Posted on Sep 10, 2008
  • 42 Answers
SOURCE: I have a GE Profile Arctica. Refrigerator side
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 29, 2009
  • 531 Answers
SOURCE: GE Profile Side By Side Melting Ice but still freezing lower half
you have adefrost problem
Posted on Apr 02, 2009
sawdust46694
  • 398 Answers
SOURCE: GE Profile Arctica freezer door not sealing properly.
Loosen the hinges on top of the door left side, . lift or lower the door till it is level with the top of the unit. now do the other door. now look at the line between both doors, and compare the gap at the top and bottom . adjust once more time if needed. clean the metal and the magnet with windex then put weson oil on a clean towel and wipe all the way around each door.. hope this was helpfull to you.... Sawdust46
Posted on Aug 11, 2009
I have a GE Profile Arctica refrigerator that I purchased used last week. Developing quite a bit of frost buildup inside the upper half of the freezer. Also noticing that the flap for the ice doesn't...
Hi yes the flap will cause the frost, you need to replace the solenoid that controls that flap, if this is a side by side, the solenoid is behind the dispenser controls on the freezer door, you take off the control board, and then remove the little mount behind that it has 4 screws and you will see solenoid on right side, it needs to be replaced.
Sean
Mar 17, 2011 | GE Profile Arctica Stainless Steel Top...
Ice/Water dispenser not working on my GE Profile Arctica model # PSS26SGPA SS. Does make ice though, just front panel stopped working. Called a tech to troubleshoot, who said it was the main...
Had same problem. Removed kick panel at bottom and found the wires from the freezer door near the lower hinge are very flimsy. The white wire was broken at the connector and the connector was corroded. Since I have no plans to remove the freezer door, I spliced the wires together with **** connectors and it's working fine.
GE could do better.
Jan 12, 2011 | GE Profile PSW26P Stainless Steel Side by...
The freezer part keeps popping open whenever you close the fridge part. How can I fix this?
The magnets in the freezer door arent making good contact, try adjusting the front legs up to make the fridge lean back slightly
Nov 25, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Top Freezer Not Cooling...Fan Running...everything thawed :(
Check the thermostat in the refrigerator and make sure it's not accidently turned to the defrost mode
Jan 08, 2009 | GE Profile Arctica Stainless Steel Top...
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
