Question about Konica Minolta Di1610 Copier
Di 1610 change tc-incorrect tc
  • Anonymous May 06, 2008
    problem with di1610.always says change t/c
  • sam gerban
    sam gerban May 11, 2010
    TC type is set to the wrong value.
    Set the TC type value to 5. To change this setting, perform the following:
    a. Press Utility
    b. Enter the Service Mode (Stop-0-0-Stop-0-1).
    c. Select number 4 Display.
    d. Scroll to TC Type.
    e. Enter 5 and exit.
    IF THIS DOES NOT HELP THAN YOU HAVE CORRUPT FIRMWARE
    hope that help
This may also be the toner sensor that sits under the drum unit on the machine. I have replaced a few of these
Posted on Mar 12, 2009
Konica minolta di 1610 replace drumkit
se mando fazer limpezas gerais sera que ele retirara o codigo (error)
Nov 12, 2012 | Konica Minolta DiALTA Di1610p Printer
Caro esperto codice errore c0510 minolta dialta di 1610 sapresti come fare per sbloccare
Amico C0510 - fusione fallita (temperatura di fusione del basso anormale) temperatura del termistore fusione roll undectable rimane al di sotto di 120 ° ... controllare il fusore
May 24, 2010 | Konica Minolta Office Equipment & Supplies
Inncorrect tc type
incorrect type of toner cartridge was installed. only use the toner cartridge that has been manufactured specifcally for this machine.
Oct 09, 2009 | Konica Minolta Di1610 Copier
Konica bizhub di1610fp priter constantly gives a paper size error and requires paper reset.
Change the paper size,emter in the user modeor press the Utility key.I have the Minolta Di 1610 (copier/printer) and every function is OK.One toner cartridge is OK for 7500 copies,if you can the setting the user tools.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Minolta Di 1610 f not starting
Scanner home position. Check the scanner itself there is a small piece of plastic that actuates the home sensor, check for dust dirt (can air) sensor is loacated under the glass left side rear
Apr 27, 2009 | Office Equipment & Supplies
How do I input ip address in Minolta DI1610
press the Utility/Counter -> Network Settings -> IP address
Feb 09, 2009 | Konica Minolta Di1610 Copier
Error code 810003c1
Hello
- It seems like somebody has hacked into your hotmail account and changed your password so you are unable to sign in.
- If messenger is tellling you: WRONG USER NAME OR PASSWORD it is that. - Otherwise try uninstalling and reinstalling msn messenger and see how it goes. - A good way to check if the password is WRONG (therefore changed) is go to www.hotmail.com and insider there put in your email and password (the ones you think are the good ones and see if it is telling you that the password is incorrect.
Failing to sign in is another thing. To check if it is a problem at your home on your computer use www.meebo.com and try sign in there. If you are able to sign in then the reinstall of msn messenger should solve your problem.
One last thing if you installed a firewall make sure that msn messenger is added as an exception in the allow programs as you will keep encountering this problem
I hope that i was able to answer your query unfortunately i dont have arabic fonts installed
Best Regards
Jan 06, 2009 | Microsoft Windows Live Messanger
CARTRIDGE WONT ALIGN
The following error message appears on the LCD panel1.gif on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Feb 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Just for information
There are several models and numerous drivers
Driver Link
Dec 15, 2007 | Office Equipment & Supplies
Konica Minolta Di1610 Copier Logo
577 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
