Question about GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White
Wat are the two heat rods in bak of freezer - GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
My 1992 yamaha virago 750 quit firing were should i start to solve this promblem
First and foremost, check your "Stator" I have an 89' XV750 and had to deal with the same issue. I put a light kit on the bike not thinking anything about power drain. Then my stator went out. After I replaced my stator, it was fine after I installed some LED volt limiters(resisters) witch are very easy to install.
Mar 16, 2013 | 1988 Yamaha XV 535 Virago DX
I was hookin my radio up nf my lights turned off for a sec den came bak on it still run ns drive but now my turn signals dnt work my windows dnt work my heat is controlling itself nf all the fuses is good...
You have hooked the car illumination wire up to an incorrect wire on the stereo, This wire is usually black and can be mistaken for an earth wire
Mar 08, 2012 | 1999 Lincoln Navigator
Mercury Sable 1996 Fuel gauge erratic how to repair it and what piece to buy ?
i would most likely replace the sending unit in the tank,this is wat meters fuel level and transmits bak to guage. i would first tap on top of dash board wen guage acts up to see if there are any changes in its erratic action,if there is then ur problem would b a faulty guage or in that area,if not then its safe to go bak to tank area an replace sending unit... good luck
Apr 27, 2011 | 1996 Mercury Sable
Freezer working /fridge not
You most likely have a failure in the defrost circuit. One or more of thee possibilities: Heating element, defrost timer and/or defrost thermostat.
Check these links:
http://appliancehelponline.com/defrostheatervideo.html
http://appliancehelponline.com/referdefrostheater.html
May 31, 2010 | Maytag MBB2256G Bottom Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Wat could be wrong
yep ! sounds like a blown diode inside alt. have it tested either on or off car voltmeter should read 12.35 volts or more, any less replace the unit. i would test the new one at the parts store. prior to install
shack
Apr 19, 2009 | Nissan Pulsar Cars & Trucks
GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White Logo
21 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
