Question about Goldstar R8000 Air Conditioner
Running Compressor Intermittently
Last night the I turn the AC to cool and the no matter where the thermostat is set the compressor will not turn on, fan runs fine, but no compressor. This morning I take the front cover off and check the wiring everything looks fine, put it back together and the compressor comes back on. It runs for a while and turns compressor off like it should. I leave it for a couple minuets then adjust the thermostat to try to get it to come back on, nothing. Also the thermostat seems to run high, by that I mean that it turns on only if above 7 (out of 9) or so. Any ideas?
  • f18_jetpilot Jul 20, 2008
    I have the same problem. it is a WG1005R.
    In the afternoon and late evenings, the compressor won't come 'till late evening 10:00 PM or so. It then works fine all night. It is set for 60 deg.
    The A/C sits in a window on West side of house. I can sometimes force the A/C to work if I turn the unit to the Dry selection.
    Where is the thermostat located? How do I get to it? And where can I locate one?
    Thanks
    Paul
    Genius:
  • 1,073 Answers
Replace the thermastat it has a bad set of contacts
Posted on May 05, 2008
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
Dometic rm7732 not cooling
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jun 17, 2008 | Dometic RM2652 Refrigerator
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Stops running thermostat
thermostat or relay module issue.
May 19, 2013 | Dometic Rooftop RV Air Conditioner
Central ac compressor keeps running
Sounds like the contactor is stuck. Turn the power off on both units and remove panel on condenser. Pull out on the contactor if engaged. Likely still needs replaced, it's going to happen again.
Jul 25, 2017 | Heating & Cooling
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Goldstar R8000 Air Conditioner Logo
299 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
