Question about Homelite Mighty Lite Lawn Trimmer
Weed eater line won't advance. - Homelite Mighty Lite Lawn Trimmer
  • 3 Answers
I know it may sound stupid but on the spool their should be arrows that direct you which way to wind the line if you just added line. Some think one goes one way and the other goes the opposite but they both go around the spool in the same way and do not go in the knotches at the top just out the holes. Make sure the spring did not fall out of spool if their is one in that model and while it is running just tap the bottom of the spool on the ground. If that does not work more than likely when you pushed the line back up into the shaft to screw on the knob the line is pinched between the two holding slots. Turn the trimmer upside down (while off) and push knob in and pull line on both sides to advance line. If line does not come out your line is wound wrong or twisted inside spool and must be untangled and reattached. Both lines run the same direction on spool!
Posted on Aug 25, 2010
Ryobi weed eater troubleshooting
Here is a video I found helpful.
https://www.youtube.com/watch?v=iMFUW6DJia0
Aug 19, 2014 | Garden
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
How to change the fuel filter on a Weed Eater Feather Lite FX265Xtreme 25cc. The weed eater stars but won't run.
Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
Oct 12, 2011 | Husqvarna Forest & Garden 125c 17"...
How do I remove the spoolhead so as to afix the pivotrim head
I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
Enjoy! :-D
Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
I have a WEED Eater Model SST 45. I left the switch on all winter and now it won't start. What is wrong?
If it is a pull start, leaving the switch on did no damage to the weed eater.
Gary
Jun 29, 2011 | Garden
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
Jun 13, 2009 | Poulan Garden
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
396 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
