Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
My compressor builds to 125 psi then shuts off like it should then when the pressure is released the compressor wont start back up. Sometimes it will attempt to start and it sounds like the motor is straining to start
    President:
  • Craftsman Master
  • 1,388 Answers
When a compressor reaches set pressure, there should be a release of air from discharge hose thru the unloader. This release of air unloads the compressor head pressure. The unloader is usually located within the pressure switch. Easy to check. Follow discharge hose from compressor head to tank. There should be a brass/steel checkvalve at the tank. The checkvalve allows air to enter tank, however not allow air to be released back into discharge hose. If this valve is leaking, air will be released from the unloader constantly. Follow 1/4" tubing from checkvalve to unloader and listen for leaks. Repair as needed. If air is not leaking from checkvalve then check unloader mechanism with-in pressure switch. Parts are available at www.toolpartsdirect.com Good luck
Posted on Aug 25, 2010
Why does compressor push oil through air filter when it shuts down ?
Minimum pressure check valve is bad. when unit shuts down air pressure goes back thru compressor and pushes oil out the air filter.
Jun 02, 2015 | Ingersoll Rand UP6-20-125 120 Gallon...
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Sep 09, 2012 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have an Ingersoll Rand T30 10 HP compressor that runs OK and will bulid up 150 psi without any problems. But when the pressure drops enough to kick the pressure switch, the motor won't start. just tries...
When the compressor comes up to pressure and kicks off, you should normally hear a gasp of air escaping. That gasp is the release of pressure from the compressor itself - not the tank, and it is supposed to get released so that the compressor can restart without being preloaded with compressed air. My guess is that the gasp is not happening. It is probably some debris or a gummy mechanism. The mechanism is supposed to be triggered by the same mechanism that shuts off the motor.
Aug 30, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Model number b600bpl60v, pressure doesn't get above 125 psi. what might be the problem and is there some type of manual available on line?
125 psi is a industry standard for air compressors. WE are not susposted to need more than that. It is going to shut off at that, 125 and not cut back on until about 100 psi.
Jun 29, 2009 | Coleman Air Tools & Compressors
Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
Jun 18, 2009 | Air Tools & Compressors
My EC12 builds up pressure, but then releases all but about 10 psi.
The non-return valve is sticking and it's an easy fix. First, for safety, unplug the electric power to the unit and release any pressure in the tanks. Then unscrew the cap of the non-return valve (between the compressor and the tanks). Inside you should find a tapered rubber plug which is probably sticking in the valve housing. Sand down the diameter of the large end of the plug, being careful not to damage the flat face at the narrow end (which is the sealing surface). For sanding try 400 or 600 grade wet-or-dry paper and sand until the plug just moves freely in the housing. Reassemble and the compressor should work. Incidentally it's an oil-type unit, and quite durable. Make sure it has enough oil.
Sep 23, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
259 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
