Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell 7920 not dispensing all of a sudden
Okay, so my friends powered this cleaner and in the midst of using it "it just stopped working." I got it back from them and found that it was clogged in many places full of dog hair. (Apparently, they didn't vaccum the carpet before they tried to clean it. I yi yi!)
Anyway, I cleared it of all hair/jams, I replaced the pump, and the belts, and water sprayed for about 10 seconds and then quit again on me.It IS pulling water from at least one area...but most of it is "dribbling" into the bottom half of the machine NOT onto the carpet.
There ARE bubbles in the lines, so I did my best to fill the lines with more liquid...in case air was causing a problem...still no resolution.
I cleaned out the heater as suggested on here also and no, the hand tool doesn't spray either. Any other suggestions?
I'm really frustrated but still think it must be something "easy" and would be ********** to have bought new parts, worked on it, and then take it to a repair shop and spend a lot of money on something still pretty simple.
    President:
  • 1,673 Answers
You could have a pinched line. When you put the top back on, the piston should have been on the bottom of the smart mix valve and in the water only setting. The heater could be plugged, which is in the handle. If water sprays out of the tool hose, then the heatr or line in the handle is clogged. Is the gasket on the water and the soap bottle on the valve at the bottom, it has to be on it not sitting in the hole.Is the top secured all of the way around, sometimes the back will back free and rise up causing problems. Spray nozzles are clogged. Try running a mix of vinegar and water to see if it will unclog it.
Posted on May 13, 2008
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
How do I fix the problem on my Bissell model # 7920-5 carpet and floor cleaner the water won't spray out onto the carpet
First check your user's guide for filter cleaning. There are two filters both small that need cleaning after each use. If that didn't clear it up call Bissell Consumer Care at 1-800-237-7691
Jul 01, 2014 | Bissell Vacuums
Bissell ProHeat Turbo Model 9300 stopped dispensing liquid, but water is vacuumed up okay.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yru347
Mar 01, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Plus carpet cleaner does not **** up water
heatman101
dghdgh
Jan 04, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Can't get the water to spray out when I turn it on?
When it doesn't dispense water or solution that means that the pump belt needs to be replaced. You can get a replacement and view the manual here:
Bissell 7920 Pump Belt and Manual
Dec 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
7920 ebissell instructions
You can try bissel.com, or the part number for a user manual is 2105811, you may be able to order it, if it is available still.
Sep 06, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell power shoot carpet cleaner
It sounds like the heater may be plugged. This is a problem for an experienced technician. The heater is located in the handle and they are prone to plugging at the tubing connections. The heater is heating soap and water solution and this can cause the soap to coagulate and plug the lines. It must be addressed carefully to avoid damaging the heater.
Mar 23, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
147 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
