I have a Ruud model number: uamb 042jaz Apparently the fan motor (the one on top of the unit below the grille) is failing. It has some oil around the bottom edge of the motor. I had someone call out to estimate the repair and was told it would be more than $1,000.00. That seems high for such a simple part/labor. Should I replace it myself? Is it a difficult thing to swap out. I am technically minded, so that part does not bother me. Thanks, D.
  • david75424
    david75424 Aug 25, 2010
    Thank you. That is immensely helpful.
    Can I rent the "puller" you described for use extracting the fan blades, or is that a specialty tool that is only available to the trade?
  • 905 Answers
Hello David,
$1000 does seem quite steep for changing the blower motor. The hardest part likely will be finding a replacement motor. There may be a reason why the high price tag. Look in the phone book, for electric motor repair / service / rebuild etc. They should be able to replace the bearings if need be.
On a different note, why do you say it is failing? Is it making loud noises, not turning very fast, not turning at all, tripping breakers, throwing GFI, etc?
A lot of motors will have sealed bearings, and should not leak unless they fail. Some motors will have bearings that need to be oiled occasionally. It is normal for these motors to leak a bit (small amount). Look closely at the motor that you have. You are looking for a small hole or oil cup that is filled with machine or bearing oil.
Posted on Aug 25, 2010
  • 407 Answers
The only problem that I have is the price that was given to you. It makes me think they have found something else wrong with your unit, but then again, some people in this business are shady sometimes. Anyways, yes, you can replace the motor yourself and it isn't that difficult. One tool that you will need is a fan blade puller, but there are a lot of pulley pullers and such that will work and you can rent them most of the time through a auto parts store, just be careful not to bend the fan blades as the can become unbalanced and cause a lot of problems. All you do is-
1. Pull the disconnect or cut all power to the unit.
2. Unscrew and gently pull the top of the condenser off. It will not come off all the way at first since the fan motor wires will still be connected. Usually they have enough play to move the top around to set it out of your way.
3. Trace back the motor wires that go into the electrical panel. Remember where each wire is connected for re-installment.Disconnect all wires and pull the top completely off the unit.
4. The capacitor inside the electrical panel will need to be replaced also. It will be a round or oval object that 1 or 2 of your fan motor wires went to. Capacitors hold electrical charge so discharge it by grounding all terminals before handling.
5. Unbolt the motor from the frame.
6. Loosen the screw that tightens the fan blade to the shaft of the motor and use a puller to remove the fan blade. Sometimes it's necessary to use some sand paper and WD-40 or other lubricant on the shaft.
7. Once everything is disassembled, take the motor with you to a local A/C supply store to get an exact replacement. The new motor will have the right size capacitor listed on the label, your old one may differ. Just ask them for the capacitor as well.
8. Now that you have everything back home, installing it is reversed from removal. Be sure that when the system comes back on, the fan is rotating in the right direction. Most new motors are reversible. The air should be blowing up towards you. The motor can still cost $90.00 and more, but not anywhere near a grand. The capacitors usually run for around $10.00. Hope this helps and good luck!
  • Brandon Berry
    Brandon Berry Aug 26, 2010
    I'm not 100% sure, but I have seen the "pulley pullers" for automotive used before. I guess it depends on the auto parts store if they will loan you one. I'm glad that I could help and feel free to ask more if needed.
Where can I get a service manual for a Ruud Ac model UAPC-42JAZ
Go to the following web address:
www.servicemanuals.net/‎
Oct 07, 2014 | Ruud Heating & Cooling
What size capacitor does the out door fan motor require on a RUUD Model number UPMC-042JAZ
call your local ruud dealer and have him cross reference model number or look on fan motor itself, if original then cross reference ok, but if it has benn replaced look on the fan itself
Jun 19, 2014 | Ruud Heating & Cooling
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
My outside condenser fan seems to be noiser than some of the newer models, I have two blade fan. Is this just norman with a 10 year old system? My system is a UAMB-48
The bearings may be worn a little in the motor. This will cause a little bit of a whining sound when the unit is running. Eventually, (if this is the problem) the motor will quit and you will have to have a new motor.
Also, make sure the outdoor coil is clean. This coil is behind the fins that are on 3 sides of the unit. You can wash this coil out with a hose and sprayer. First, disconnect power before servicing. Mark
Aug 19, 2011 | Ruud UAMB Air Conditioner
Need a part number for fan motor on UAMB-036JAZ
Hi, what you need to do is gain access to the motor its self. If it is the condenser fan motor or the blower motor . This is a 3 ton unit from the numbers you have given me. There are two ways you can do this. On the data plate on this Ruud unit, normally they are paper with a plastic coating on Ruuds and Rheems, and it will tell you the H.P., size like 1/3, amperage, and the R.P.M.'s. Then get all of the model number and serial number from the unit. The best way is to get the information from the motor its self. It has the voltage, amperage, name of motor, example a G.E., the part number, Horse power (H.P.) r.p.m. such as 1725, 1100, and so on. Rotation, CW or CCW. The new motor will be reversable, just change 2- leads on it. This would be your best bet, to do it this way.
please don't forget to rate me and I know you will be kind. I cant give you the numbers as they will use different motors in the same unit, and different brand names.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
May 29, 2010 | Ruud UAMB Air Conditioner
We have a RUUD AC unit, model number UAMB-042JAZ. ...
Those are the low voltage wires from the thermostat and transformer. Yes he can just match up the colors and splice with wire nuts or something else to hold the tight. If the transformer got shorted out during any of this it may need to be replaced. Hook them up and if the unit runs, then no problem with the transformer.
May 21, 2010 | Heating & Cooling
Daily reset of outside unit
I have the same unit and was having the same problem. My brother works on A/C's and told me that the coils most likely needed cleaning from the inside out because when they are clogged with a lot of debris the system will overheat and cause that switch to trip and so far it has worked. What you need to do is turn the main breaker off to the outside unit first then take the four screws out of the top of the unit, use a flat head screwdriver and lift the fan it's self up out of the carefully taking caution of the wires going to the fan, then take the garden hose with a spray nozzle and wash the coils from the inside spraying through the coil to the outside and then wash the louvers off of all the debris and this should help.
Jun 29, 2008 | Ruud UAMB042 Air Conditioner
Ruud air conditioner unit
sounds like you have a fan blade out of balance or one that is bent which when the unit winds down it becomes out of balance use a straight edge across the blades to see if any are bent.
Jun 12, 2008 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
