Question about Proform XP Weight Loss 620 Treadmill
I have a proform XP Weight Loss 620. The drive belt slips every time a hard step is taken on the treadmill. The belt appears to be in good shape. What else could be causing the belt to slip?
  • 128 Answers
There si an adjust ment on the belt if you have a manual it would tell you where the adjustment is
Posted on Aug 25, 2010
Belt slips when running on treadmill
see the video and proceed according. God bless you
Jan 31, 2013 | Proform XP Weight Loss 620 Treadmill
Belt is slipping
hi,
You have to tighten the treadmill belt ,for that watch the following video.
ok
Aug 13, 2011 | Proform XP Weight Loss 620 Treadmill
I have a Pro Form XP 620. How do I tighten the belt
http://www.youtube.com/watch?v=AZSMLpXm-tA&feature=related
PLEASE DO IT WITH CAREFYLLY AND PACIENCE.
Do not overtight the belt, can overcome another problem,like overheating.etc.
sincerely.
Jun 23, 2011 | Proform XP Weight Loss 620 Treadmill
When walking on my pro form xp weight loss 620, while walking along fine, every so often it starts to make a slipping sound and seems like the belt is slipping. tried tightening the belt and still does the...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jul 07, 2010 | Proform XP Weight Loss 620 Treadmill
ProForm XP Weight Loss 620 Treadmill: i have lost the kye can it start running without i...
Generally NO, but try something like a fridge magnet, it worked for me on my HyperExtension treadmill
May 17, 2010 | Proform XP Weight Loss 620 Treadmill
The walking belt on my Proform 620 weight loss treadmill is very slick, almost dangerous
You can usually find the screws to tighten the belt at the back of the machine - but be careful not to tighten too much. A quarter turn may be all that is needed. A gentle tug will get the belt back into alignment if it is askew. Remember that if you have trouble tightening or realigning the belt, you should seek advice from the manufacturer or the fitness store where you bought your treadmill exercise equipment.
Most new treadmill machines do not require belt lubrication, and therefore you should only lubricate your belt if the manufacturer specifically recommends it. Most of the manufacturers who do recommend regular lubrication sell kits with instructions and all the equipment you need to make quick work of the task.
Post further comments for more help or information.....
Good Luck!!
Thanks
Dec 04, 2009 | Proform XP Weight Loss 620 Treadmill
Latchknob completely off, how do i put it back on
Make sure your tension spring is in place. Insert the plunger from the inside out with the spring in place. Then screw your knob into the plunger and you should be fine.
Apr 13, 2009 | Proform XP Weight Loss 620 Treadmill
My new treadmill belt is to tight, motor won't run
i discovered a bolt protruduing about one inch just behind the drive belt from the moto to the roller. The drive belt had gotten over the bolt and that was causing the interfearence.
Apr 09, 2009 | Proform XP Weight Loss 620 Treadmill
Treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Feb 22, 2009 | Proform XP Weight Loss 620 Treadmill
Manual
Proform's website has owners manuls:
http://www.iconservice.com/proform/manuals.html
The list of available ones for your model are at:
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/proform/manuals.d2w/report?man=PROFORM&name=50071&lan=&x=0&y=0
Jan 10, 2009 | Proform XP Weight Loss 620 Treadmill
Proform XP Weight Loss 620 Treadmill Logo
312 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
