Question about BypassKit - NISSDL - Nissan And Door Lock Alarm Interface Bypass M
I have a 1992 infiniti G20. I cannot get it to even start. How can I remove or reset the security alarm. I think it locked it and now the car is unmovable.
  • e_lopez60858 Aug 25, 2010
    I tried that several times. no luck
  • 29 Answers
Try to use the factory key in the driver door.. shut the door. lock it then unlock it.. that should disable the anti theft..
Posted on Aug 25, 2010
  • doooogle
    doooogle Aug 25, 2010
    ok then the only other solution i could think of would be to turn the car off take the key out open the hood and disconnect both battery terminals.. then touch them together and hold it for a few minutes. they aren't connected to the battery therefore there is no power on the cable so it will not fry anything.. what will happen is you will drain the power from every electronic in the car. there fore all the memory will be lost. With your ecu not having any memory of it being in anti theft mode once you hook them back up you will have full power back on everything and a fresh start.. a lot of the high end vehicles have this problem and as a mechanic of the last 16 years i have found this trick to work time and time again...
How do you get to fuel pump on 1992 infinity G20?
There should be an access port under the back seat (buttocks cushion). Remove back seat and you will see a round plate. Under plate is fuel pump. Recommend buying repair manual for the car at an auto parts store before starting.
May 18, 2016 | Cars & Trucks
2004 INFINITY G35 REPLACED ENGINE. LOST FOB. ALARM GOES OFF AND CAR WILL NOT START. HOW CAN I BYPASS ALARM
the alarm will be deactivated by key in door lock unlock, the no start is not alarm, check security red led is on, indicating key programing needed
Sep 23, 2015 | 2004 Infiniti G35 Sport Coupe
1994 lexus es 300 starting issue / alarm reset?
I think that's the alarm system as well.the most important thing is the alarm system is still working?step out yr car try to use remote key to lock n unlocked,if that's working.i don't worry at all.lock n unlock are alarm system reset itself.should be normal,battery is super low or dead .good luck for u
Jan 20, 2014 | Lexus ES 300 Cars & Trucks
What is this?
Manual for the 1992 Nissan Infinitu G20 Also sold as the Primera in some countries?
http://www.cars.com/infiniti/g20/1992/
May 11, 2012 | Chevrolet Cars & Trucks
Whats the switch the clutch hits in my 1999 infiniti g20 called?
It might be the "Clutch Starter Safety Switch"... from NAPA part number ECH NS5858
Look up on the NAPA site and compare picture.
Nov 01, 2011 | BypassKit - NISSDL - Nissan And Door Lock...
My car alarm triggered off and now my car wont start.
under the steering column on the left there is a fuse box there are three metal fuses larger than the normal fuse...there is a tiny hole it is the reset button for the theft detection...check the manual...should be around page 194 i think...you just stick a pin into the hole and should reset.you migt need the alarm code to release the lock on te engine.depends on what type of alarm it has installed...
Mar 12, 2009 | 1992 Lexus Ls 400
Engine will not crank, cannot get security alarm to reset
check the fuses for the alarm you might have blown them which would not let you start the car. word of advice never mess with car alarms and never jump your lawn mower with your car.
Sep 24, 2008 | 1992 Chevrolet G20
BypassKit - NISSDL - Nissan And  Door Lock Alarm Interface Bypass M Logo
900 people viewed this question
Top Infiniti Vehicle Parts & Accessories Experts
advance tire and...
Level 1 Expert
tjonesauto
tjonesauto
Tom Chichester
Are you an Infiniti Vehicle Part and Accessory Expert? Answer questions, earn points and help others
