I have a whirlpool duet washer and dryer model #GHW9400PL. i am unsure of the exact source. i dismantled the plate underneath the door and noticed a drip coming from above. i have researched a little and noticed alot of people claiming a "bellow" issue. i am wondering is there any other reasons for there to be a leak coming from the same location? if not do you reccomend i replace the bellow? thanks.
jsrock516
  • 5911 Answers
SOURCE: Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Posted on Sep 29, 2007
aborcass
  • 2651 Answers
SOURCE: Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response http://www.keshakeaway.com/servlet/StoreFront
Posted on Mar 13, 2008
Lumpy816
  • 246 Answers
SOURCE: Replacing bellows on Whirlpool Duet HT model GHW9400PL0
I have not seen a tech sheet (or service manual) that details how to remove one of these. Basically, once you have your replacement boot (availible at local parts stoares or from the manufactures web site on line), You can follow these steps:
1 - Remove the front clamp. (a silver peice of wire with a spring at the botom) A small flat head screwdriver will let you pull it off.
2 - You will have a clamp on a hose that comes from the dispenser to the boot on some models that you will have to disconnect.
3 - There is a second clamp on the tub side itself. Remove it by using a short phillips head screw driver to unscrew it.
4 - remove the boot
5 - Reverse the procedure making sure to line the new boot up at the top. (there is a arrow that needs to be ligned up on the tub and the boot.
Taking the lower front panel off can give you a bit more room to work. You can take it off by removing the screws at it's bottom.
Posted on Jun 16, 2008
jsrock516
  • 5911 Answers
SOURCE: need instructions to replace the
Here ya go...follow this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you get stuck along the way and/or require further assistance, please let me know. I hope this helps you.
Posted on Jul 04, 2008
SOURCE: Replace bellow seal
Posted on Jul 18, 2008
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
Ghw9400pl0 door
Your model doesn't allow for door reversal on the washer due to the electrical with the door lock, but you can the dryer there is a kit you can purchase with the dryer model number
Jan 17, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F02 error on whirlpool front load washer. How do you open the kick panel?
Depending upon what model you have, most kick plates are removed by taking the 3 or 4 (1/4 inch or torque) screws out located underneath the kick plate. Note that not all front load washers have a kick plate so be sure that there is a prominent gap between the upper most region and the small lower region being the kick plate.
Apr 22, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
Apr 09, 2009 | Whirlpool Washing Machines
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Whirpool duet front load washer door trouble
I have stacked ours too, though after 5 years we have not had any issues with the pressure. I would suggest checking the screws holding the hinge in place as they may have loosened or been tightened with the door not properly lined up.
Aug 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
